Sponsored by: Auxito
5.4L rebuild or replace
Old Feb 22, 2008 | 08:16 PM
gator120's Avatar
gator120
I have a 2001 f-250 with 5.4L and the #6 piston is burn't. Theres 160,000 highway miles on the motor. Thinking of putting a good used motor in, but also considering repair. Whats the normal life of these engines. Suggestions? Thank You.
Old Feb 22, 2008 | 09:39 PM
Ultramagdan's Avatar
Ultramagdan
Welcome!
How did the piston get burnt? The 5.4 is good for more miles than that. People report 250K with no problems and one guy has 1 million on his.
Old Feb 22, 2008 | 09:53 PM
jkhaltom's Avatar
jkhaltom
I just rebuilt my 5.4 '01 SuperCrew's engine a month ago. Set me back $750. Required absolutely no machine work. The rebuild was easy, getting the engine in and out of the mounts was tough. Had heads rebuilt for $90 each, bought gaskets, head bolts, bearings and rings from the same machine shop. Engines now days are a lot better than what we're used to. There was absolutely no wear on the cam, crank or cylinder walls. I had leaky valve guides on one cylinder that caused oil burn, fouled plugs and oil in the intake. Sounds like your having the same issues. I recommend the rebuild.
Old Jan 31, 2010 | 01:07 PM
cjncrckhead17's Avatar
cjncrckhead17
same idea
i havent decided to rebuild or replace because i need a tune up but i havent had any trouble out of my motor butt im about to twin turbo it so i have to either replace with a new one or rebuild the old one so any ideas where i can
PROBIKE101
WTB - Parts & other
Apr 29, 2016 08:57 PM
Hogin
Modular V8 (4.6L, 5.4L)
Oct 3, 2014 06:06 AM
Xx0573
Jul 3, 2013 11:32 PM
TBFGhost
Nov 10, 2010 06:23 PM
slopdogg250
Nov 28, 2009 12:37 PM
