Are gauges really needed?
Old Feb 25, 2008 | 01:14 PM
  #31
Izzy351's Avatar
Izzy351
Originally Posted by jhorton
Izzy, I was looking at the diesel manor site and noticed a lot of drilling and tapping. Are you saying that a person has the choice to either drill and tap or use a factory plug? I can handle the tranny plug and the boost "T" fitting. I just don't want to drill and tap anything.
Sorry -- I wasn't clear. The EGT probe requires a drill & tap for the kit I have, but you can get a sensor that just uses a band clamp and a non-tapped hole. The drill & tap is really the best way to go, but a lot of folks have done the clamp method without problems. I actually went in the up-pipe instead of the manifold, so that tap job was very easy. Up to you, but you will need a good drill bit or two to do it iright. The Drill Dr. is a wonderful tool...
Here's what my EGT probe install looks like:
Old Feb 25, 2008 | 01:46 PM
  #32
missouguy's Avatar
missouguy
[QUOTE=Izzy351]Sorry -- I wasn't clear. The EGT probe requires a drill & tap for the kit I have, but you can get a sensor that just uses a band clamp and a non-tapped hole. The drill & tap is really the best way to go, but a lot of folks have done the clamp method without problems. I actually went in the up-pipe instead of the manifold, so that tap job was very easy. Up to you, but you will need a good drill bit or two to do it iright. The Drill Dr. is a wonderful tool...
I used the clamp type pyro sensor mount. It was really easy and after two years it is still working fine.
Frank
Ryck
Mar 8, 2014 03:09 PM
Heyer5
2004 - 2008 F150
Mar 29, 2011 08:32 AM
ShamelessMT
Jun 25, 2009 02:55 PM
bbrowning
Bronco II
Aug 24, 2004 08:46 PM
90EBBronco
1978 - 1996 Big Bronco
Aug 24, 2003 01:41 PM
