Sponsored by: Auxito
Hot air
Old Feb 22, 2008 | 04:52 PM
dahn's Avatar
dahn
Hot air
98 F150 I turn the thermostat to cool air on the dial but it stays hot? Can you change the switch behind the dial? Is it the door most of the time being broken,I've seen where some people bought a blender door fix kit on ebay what comes with the kit? thanks
Old Feb 22, 2008 | 05:19 PM
steve(ill)'s Avatar
steve(ill)
pull the **** off the control (hot-cold) and see if the shaft is moving when you twist the ****. if it is, the probably the blend door. at the bottom center of the dash board, take the black plastic trim piece setting on the transmission hump off--- look up.
Old Feb 23, 2008 | 09:07 AM
sheetsd66's Avatar
sheetsd66
Mine did the same thing. Do what Steve the guru said......pull the floor vent trim piece off and have a look at the blend door actuator. Its an electric motor with a white plastic housing sandwiched between the transmission hump and the heater plenum. When you turn the heat control **** you should be able to see the shaft move. If you can't see the shaft, remove the three screws that secure the actuator to the plenum and let it drop down a little. If the actuator is working your problem is more than likely a broken blend door. Replacement is about $45 thru the dealer or $12 thru NAPA.
Old Feb 23, 2008 | 09:25 AM
typhus's Avatar
typhus
Before you do all that, I would recommend making sure that its not just your **** being stripped out. I know that sounds kind of simple, but I was having the exact same problem, and my dial would turn from cold to hot and stay in place and feel stiff like it always had when turning from cold to hot, but it was stripped just enough to just be riding over the adjuster behind it... fooled me good.
20 bucks from the dealer and about a 3-5 second fix.
Ooops,,, sorry steve, just noticed that you already suggested checking that first... my bad.
Old Feb 25, 2008 | 04:18 PM
dahn's Avatar
dahn
blend door
Thanks,I'll try that
Brian Frank
May 24, 2016 06:41 PM
aquaman
2004 - 2008 F150
Sep 18, 2010 09:08 PM
eds34pc
Mar 26, 2005 10:47 AM
davelaboss
1983 - 2012 Ranger & B-Series
Oct 30, 2003 02:50 PM
