Sponsored by: Auxito
'97 5.4L Engine swap
Old Feb 21, 2008 | 08:25 AM
snod_ix's Avatar
snod_ix
Ok here's the deal I have a '97 with a 5.4 and the engine has given up the ghost. I found an '03 5.4 from a truck that had been rolled with only 2500 miles on it. Will she drop in and bolt right up? What do i need to know.
Old Feb 21, 2008 | 10:17 AM
chrisf250-460's Avatar
chrisf250-460
welcome to FTE.as far as i know i believe it will bolt up with no problems,however im not sure if you would have to change computers to run it.im sure someone will come along and answer this question .i too have been wondering about this. what happened to your 5.4 exactly?
Old Feb 21, 2008 | 10:27 AM
snod_ix's Avatar
snod_ix
I say it has given up the ghost, that's not exactly true. The trunk has 193k on her, and now has 0 compression on cylinder #7 so i'm assuming burnt valve or burnt piston. I havn't yanked it apart yet to see, at anyrate I'm figuring a valve job will be around 500-700 dollars, and a complete rebuild will be more, I found the engine for around 1400 so i'm thinking i'll just spend the money now and drop a 'new' engine in and be done so i don't have to go pulling it again in a few years.
Old Feb 21, 2008 | 10:44 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
should swap straight across, and the computers will work fine, im not sure if the exact tuning is the same , but it will probably run better because the newer motor will have PI heads, vs your 97' will have non PI heads, its a boost of about 30hp and 10ftlb
Old Feb 21, 2008 | 11:25 AM
Club Wagon's Avatar
Club Wagon
Do a quick check to compare the electrical connections. I'd thought that FORD changed the style of electrical connectors between those years. Compare to judge if the wiring will be compatible or you'll need to swap components. Otherwise it should bolt up.
Old Feb 21, 2008 | 11:59 AM
BURNSTOUGHFORD
the 4.6l had coilpacks, but the 5.4l has always had the COP system, im pretty sure it wont matter if he uses all the electronics off of his current 5.4l...the only difference will be the heads, but its just in the porting and the cams
Old Feb 21, 2008 | 01:07 PM
galaxie641's Avatar
galaxie641
There are some differences on the '99+ connections and fuel system but you would be using your '97 harness and fuel rail so it should be darn close to plug and play. The newer motor will have an "extra" sensor or two that would probably just be left unplugged since your harness wouldn't have the connections.
Old Feb 21, 2008 | 10:32 PM
BURNSTOUGHFORD
what plugs are you talking about? because my 4.6l was non pi meaning it was the same as 97-98-99 and my 5.4l was a 2002 and actually my 4.6l had one more plug on it for the variable volume intake which the 5.4l dosnt have....
please enlighten me ...im curious about this
memphis_made
1997 - 2003 F150
Jun 5, 2012 11:45 AM
badfl97
2004 - 2008 F150
15
Mar 20, 2012 01:50 AM
GeorgeK
Modular V8 (4.6L, 5.4L)
Feb 23, 2003 09:22 PM
