Water Pump Wrenches Update
Old Feb 20, 2008 | 07:28 PM
kawa's Avatar
kawa
I got to looking at my water pump and there is only one "Boss" to put a wrench on and that would be the the 48MM or 17/8 and that appears to be attached to the pump. Where does the other wrench go???
Rog
Old Feb 20, 2008 | 08:01 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Are talking about the fan clutch wrenches? If so, one goes on the fan clutch nut and the other is a pulley holder.
Old Feb 20, 2008 | 08:02 PM
FARM69's Avatar
FARM69
Isn't a 55mm and 1 7/8 inch for the fan clutch removal tool?
Old Feb 20, 2008 | 08:58 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
IIRC is 58 mm and 1 7/8 inch.
Old Feb 21, 2008 | 03:39 AM
Cuda_jim's Avatar
Cuda_jim
Rog
Do you mean this one?
It spans across the 4 bolts that hold the pulley to the water pump.
A strap wrench or a big set of channel locks on the pulley will work too. Use rubber hose over the jaws on the channel locks so the pulley doesn't get buggered-up.
Old Oct 10, 2008 | 06:45 PM
Eric_F250's Avatar
Eric_F250
so... looking at the engine from the front bumper, and the pulley held still- i turn the 47 mm wrench to the passenger side or the driver side to loosen? there is a sticker that says "RIGHT HAND THREAD". confused... thanks!
Old Oct 10, 2008 | 06:51 PM
c00nhunterjoe's Avatar
c00nhunterjoe
air hammer with a blunt tip chisel works great too....
Old Oct 10, 2008 | 06:56 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
to the passenger side IMO.
Old Oct 11, 2008 | 12:11 AM
Eric_F250's Avatar
Eric_F250
thank you- it was indeed to the passenger side.
Old Oct 13, 2008 | 12:39 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
No problem, any time, glad to help you.
264WSM
Ford Truck Parts for Sale
Aug 18, 2012 09:33 AM
bigcountryfs
6.4L Power Stroke Diesel
Sep 23, 2011 09:20 PM
mudmaker
20
Jul 3, 2009 10:05 AM
kawa
Feb 20, 2008 01:22 PM
AeroDuke
Aerostar
Apr 27, 2006 09:31 PM
