Chain Wrench vs. Rope Wrench 2 remove water pump pulley
Hi, I have a 1994 ford aerostar 3.0 and need to replace the water pump. The manual calls for a "chain wrench". So far, this item is unavailable. I have been offered a "rope wrench". Will that work? Also, any tips anyone might have are extremely welcomed. Thanks
I think you are asking about removal of the fan clutch with the reverse thread nut? When I replaced my water pump, '93, 3.0, I wedged my rubber handled hammer in between the belt and pulley which held the crank from turning. It actually did not take much to loosen the nut. The rubber did not distort the pulley. Remember, it is a reverse thread.
The fan clutch failed in my 94 3.0 maybe 2 months after I bought it. My wife drove it hot, cracked driver's side head.
I had to pull the waterpump and fan assembly off as one unit. After several attempts and a broken chain wrench, I took it to a local dealership, and after various methods/tools were used, they ended up having to cut it off with a torch, so I could salvage the fan blades.
If in doubt, REPLACE it now! Do not drive these vans if overheating, pull over and park it.
M
M
TomBrooklyn2
25
04-29-2015 09:34 PM
b4hntn
1978 - 1996 Big Bronco
06-21-2008 05:51 PM
87 b2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
11-29-2004 08:22 PM
