which d60 do i need?
Old Feb 19, 2008 | 06:11 PM
crescentwrencher's Avatar
crescentwrencher
if i were to put a dana 60 in the front of my 75 f250 which one would i want
could it be out of say a dodge or chevy? is there different lengths?
info please
thanks!
Old Feb 19, 2008 | 06:14 PM
STGFordCrazy04's Avatar
STGFordCrazy04
You really want one from a 78-79 but expect to pay $1000 plus. Later model ball joint 60s can be had for less ($800 or so) but much more is required to fab up spring mounts.
Chevy is a no no because the pumpkin is on the wrong side of the axle
Old Feb 19, 2008 | 06:21 PM
crescentwrencher
well fabrication is no problem, being that i was previously a welder and now am a machinist, so basically any d60 from a ford will work it just depends on how much it will take to do it? correct?
Old Feb 19, 2008 | 06:23 PM
STGFordCrazy04
thats it. you will have to outboard your driver side spring mounts to line up with the cast in spring perch. The passenger side perch can be cut off and moved.
Old Feb 19, 2008 | 09:46 PM
X36's Avatar
X36
Like STG said 78 or 79 is the one you want.Fabbing is one thing,but the real beneficial difference is they have the king pins instead of the ball joints
Old Feb 19, 2008 | 10:10 PM
79f150toy's Avatar
79f150toy
you mean instead of ball joints, not tie rods?
Old Feb 19, 2008 | 10:43 PM
X36's Avatar
X36
Absolutley
Old Feb 19, 2008 | 11:41 PM
masterbeavis's Avatar
masterbeavis
Aint nuthin wrong with a balljoint 60, if properly maintained. Ditto however on the 78-79 for your rig.
Old Feb 20, 2008 | 12:27 AM
RCrawler's Avatar
RCrawler
I think the biggest downfall of the ball joint 60 is the lack of options for high steer, if you need that option.
Jason
Old Feb 20, 2008 | 06:51 AM
highboy1975's Avatar
highboy1975
the 78 d60 fits under mine beautifully. im getting a set of dougs over the frame headers for clearance because the u-joint is beating the snot out of the downpipe.
Old Feb 20, 2008 | 09:12 AM
crescentwrencher
a 78 79 would be better, but ive found other d60s of later years for like 300 bucks. and a $1000 doesnt sound to fancy right now.
what is high steer?
Old Feb 20, 2008 | 09:19 AM
masterbeavis
If you are finding 86-97 balljoint and kingpin D60s for $300, I highly suggest you snap every one of them up and resell them. You will make at least $5-600 in profit. OR if that does not suit your fancy, tell me where they are, and I will make the money. Buy them at $300, sell for at least $900(don't sell them too cheap) make your money for the correct axle in two sales.
Old Feb 20, 2008 | 10:48 AM
STGFordCrazy04
A ball joint 60 for $300? Ill take 2 now.
A kingpin 60 for less than $1000? Ill take 1 now.
Let me know when youve filled my order and are ready to ship
Old Feb 20, 2008 | 10:56 AM
masterbeavis
BACK OFF, I have dibs!!!
Old Feb 20, 2008 | 11:04 AM
STGFordCrazy04
It seems they are plentiful and cheap. Im sure he can find enough for both of us at those prices.
