the 2d pic is the one I was referring to that goes with the speedo I think. other 2 not sure. On my 4.0 I have the O2 sensor wires that have to be plugged in maybe one of these is for that?
I was just looking at the vss switch on the auto zone site it looks like my connection would hook right up.
I'm thinking maybe I broke part of mine off when moving the trans around while cleaning.
Thanks in advance,
Johnny
Thats the switch next to the connector in pics 1 & 3.
btw, I got the master bled and installed today. Hope it works alright, seems like a good pettle. I'll pick up a new switch and install tomorrow. I'll let you know how it goes.
Thanks again for all your help,
Johnny
I took some pics showing my master with the wheel well removed and some showing the reverse light switch and VSS (VEHICLE SPEED SENSOR) switch.
Hope they help some. http://s247.photobucket.com/albums/gg158/jpj64/
I dont have a clue on these, I dont haveything like them on mine. I have 2 connectors as I recall on the trans, and the 2 O2 sensors. Need to get someone with a 4 cyl same year mod to answer on these!
I finished this clutch job and I’m very satisfied with how it turned out, other than a few cuts, bruises and sore mussels.
I did have a more difficult time with the bleeding than I thought I would. I bleed the master with the reservoir and all lines attached put it in truck and had too much air in it. I couldn’t get the circlip out, so out it came again. I re-bleed it and this time no air, just for precaution I got my wife to come out pump it while I bled the slave.
I couldn’t have done it with out your help.
BTW, I bought a CD on e-bay it’s made by Sterling Ind. For Ford, it was only $34.99 it seems to have a lot of information. I’ll find out how accurate it is when I try to use it on another job. It seemed to be accurate with this clutch job.
What do you think?
1996 Ford Truck Service shop Information CD. Original Ford Motor Co. service publication that is not time sensitive (you do not have to reset your computers date!). This disc is new and unused; I checked it to get the following information: applicable truck lines include- Econoline Van, Bronco, Cargo, F150, F250, F350, Explorer, F Series Super Duty Truck including 7.3L Power Stroke Diesel, F & B series, L series, Aerostar, Ranger, Windstar, and Villager. Disc includes complete service information including Powertrain and Emission Control and Wiring Diagrams.
