1978 - 1996 Big Bronco
Code 34 help
Old Feb 19, 2008 | 12:46 PM
lacucarachaloco's Avatar
lacucarachaloco
Code 34 help
I have a 1990 Bronco 5.8efi e4od. I'm getting a 34 trouble code on my obd1 scanner. The book says this is some form of a voltage issue. If anyone could give me a little more info or tell me how to fix it that would be great.
Old Feb 20, 2008 | 07:32 PM
TimmyAbrams's Avatar
TimmyAbrams
it deals with your egr valve. The sensor that plugs into the top of it is getting too much voltage when the valve is fully closed. Try dissambeling it, cleaning, and then run test again.
It sould not be throwing a CEL from what I remember. Clean it, then try again. Post your results.
Tim
Old Feb 21, 2008 | 12:17 PM
lacucarachaloco
I just replaced the egr valve.. all the codes are cleared.
thanks for the help
Old Feb 21, 2008 | 05:40 PM
TimmyAbrams
No problem...
Old Feb 9, 2009 | 01:11 PM
cougarco93's Avatar
cougarco93
when your egr was acting up what did it do
Old Feb 11, 2009 | 10:53 AM
cougarco93's Avatar
cougarco93
how did your truck act before you changed egr valve. did it act like it was running out of gas
Kyle Campbell
Jun 8, 2017 03:26 PM
liquidlounge
Aug 18, 2016 06:09 PM
Steve369
Feb 4, 2016 10:25 AM
broncorif
Mar 23, 2010 06:20 PM
Neal 97 250
Feb 3, 2010 02:05 PM
