Check engine light code help needed 89 f250
Old Jun 5, 2017 | 06:53 PM
Kyle Campbell's Avatar
Kyle Campbell
I got code 18, 34, 82
code 18 tach input to pcm signal lost (I've already replaced icm)
code 34 evp sensor above threshold (egr was replaced)
code 82 air management 1 ckt malfunction .
any ideas on testing and figuring out my problem. Thanks
89 f250 460
Old Jun 5, 2017 | 07:45 PM
Kyle Campbell
I tested egr vacuum sensor
Sensor was within specs and wss getting voltage .
could my air management circuit 1 sensor be setting this code ?
Old Jun 5, 2017 | 10:13 PM
rla2005's Avatar
rla2005
Were these codes from KOEO, CM, or KOER?
The definitions frequently change depending on when they were displayed.
Old Jun 8, 2017 | 01:13 PM
Kyle Campbell
Codes
they were displayed in koeo and koer
Old Jun 8, 2017 | 01:37 PM
rla2005's Avatar
rla2005
Code 18 (KOER): SPOUT circuit open
My manual does not show that is a KOEO code.
Code 34 (KOER/CM/KOEO): EVP voltage above closed limit
Code 82 (KOEO only): Air Management 1 (AM1) circuit failure
Code 34 is probably a bad EVP sensor if the code is from KOEO. If it comes up only in KOER then you probably have a leaking/bad EGR Valve Regulator (EVR).
Code 82, is the TAB/TAD solenoid plugged in? Since you have a F250 you probably only have the one solenoid.
Old Jun 8, 2017 | 01:44 PM
Kyle Campbell
Codes
thanks for quick response. Yes I think what's happening with the code 18 is my ignition control module keeps getting loose distributor mounted.
the code 34 . I have replaced the egr valve already . Tested the sensor and was within specs .
as far as the code 82 is that the sensor that's near the ignition coil ? If so yes it's plugged in
Old Jun 8, 2017 | 03:26 PM
rla2005's Avatar
rla2005
Is the SPOUT plug inserted in the holder? This is the shorting bar that allows the computer to control the timing signal to the ICM. Code 18 indicates there is an open circuit.
What was the EVP sensor output KOEO and KOER?
I do not have a good picture of a single TAB/TAD solenoid, but yes it is a single solenoid (not a sensor) near the distributor. Unplug it, then measure the resistance with a meter. It should be very close to a short circuit.
Rdamore008
Nov 24, 2016 03:47 PM
93truck
Jun 15, 2006 09:53 PM
Goulette55
Jan 20, 2006 09:19 PM
SadButTrue
Apr 30, 2000 11:38 AM
