383 Cleveland
Old Oct 11, 2002 | 09:07 PM
335clevo's Avatar
335clevo
383 Cleveland
Will a 383 Cleveland (351C stroker) do a better 1/4 mile time than a stock 351? I know it should make more hp and torque, but won't a longer stroke cut down on its ability to rev quickly?
335C
Old Oct 12, 2002 | 07:40 AM
shazam's Avatar
shazam
383 Cleveland
>rev quickly?
>335C
It's ability to Rev Quickly will be off set by the greater Torque this motor will make.Torque is what make you go forward so if you have more of it you should go forward faster.
Bill,Bubba,Wayne Your thoughts on this.
ShaZam
Old Oct 12, 2002 | 09:41 AM
Brian S's Avatar
Brian S
383 Cleveland
My theory is that the shorter stroke 351 will rev faster than a 383 IF the trans is in neutral. All you are dealing with is the internal friction and weight of the reciprocating assembly.
Once there is a load, I would think the more powerful engine would overcome the load faster and will be the one that revs more quickly.
Someone correct me if this isn't right.
Old Oct 12, 2002 | 12:10 PM
FORDNUTTZ's Avatar
FORDNUTTZ
383 Cleveland
its both and not either at the same time
the fastest reving engine i ever heard was a 460 in my friends racing truck
its all how the engine is set up
cam,compression, clearences everything
ignition and carb are important also
( i know i cant spell so why dont this board have a spell checker )
Old Oct 13, 2002 | 04:03 AM
335clevo's Avatar
335clevo
383 Cleveland
Thanks fellas.
I have a mate with a 302 that goes like hell on short drags, and he says it's due to the short stroke, of the 302. When another bloke told me he stroked his 302 out to 383, and was beating every 308 commodore he went up against, it just got me wondering.
335C
Old Oct 15, 2002 | 11:40 PM
SOBCspeed's Avatar
SOBCspeed
383 Cleveland
Yes, going to a longer stroke decreases you upper rpm performance compared to your lower end, but it still makes more power at higher RPMs compared to a stock engine.
As was mentioned earlier, the extra power will move the car faster, resulting in faster revving. For drag racing, bottom end is kind of more important...
Old Oct 18, 2002 | 09:37 AM
kid vishus's Avatar
kid vishus
383 Cleveland
The fact a car runs faster in the 1/4 has no bearing on how quickly the motor revs. If the motor makes a ton of mid rage torque, then keeping the motor in the torque band longer will make it run faster. My stock rod cleveland has run 6.18 in the 1/8 using a 4.86 gear. A buddy who has a BIG bbc, uses a 4.11 gear, and his car runs 5.80's. My car rev's a ton quicker than his, but his car is faster becouse it makes more torque and HP. My little motor makes no low end torque, but makes a bunch of upper rpm HP, that's what makes my car run the way it does. My buddy's motor makes a bunch of low and mid range torque, that's why his runs the way it does.
To answer the originall question, a stroked cleveland will outrun a stock stroke celveand if both motors are built equally. But, the bigger motor wont necassarily rev quicker, it will just make more power.
Old Oct 18, 2002 | 02:20 PM
blu93gt's Avatar
blu93gt
383 Cleveland
pcmenten
Dec 15, 2002 08:24 PM
335clevo
May 27, 2002 06:48 PM
335clevo
May 6, 2002 08:13 AM
335clevo
Apr 12, 2002 09:43 PM
335clevo
Sep 26, 2001 05:25 PM
