tires...
Old Feb 18, 2008 | 08:11 PM
Pfeifferj's Avatar
Pfeifferj
tires...
Im considering putting meaty tires on the back of the 56. Any good tips on what combinations to look at? I beleive the stock steel rims are 15". Should I just get a bigger tire in the back or have to size up on the rim. I want this to give the rear end a little bit of a lift, while fitting under a stock wheel well.
Old Feb 19, 2008 | 08:39 AM
49willard's Avatar
49willard
I just went thru this process on my 49 but I do not know how much you have to work with in a 56 wheel well. My 49 had just over 12 inches of wheel well width to work with. I ended up with 265 70 15 tires which are 10.4 inches wide to maintain an inch of clearance to the fender and to the bed. They are on 8 inch rims with 4 1/2 inch backspace.
Someone should chime in that has been down this road with a 56.
FordFanFrits
Jan 3, 2011 07:35 PM
Vaccuum
Nov 18, 2010 11:54 PM
damicofuel
Mar 29, 2010 11:38 AM
frdf250
Sep 1, 2009 09:14 PM
horizonhuskies
3.8 & 4.2L V6
65
Mar 4, 2004 07:07 AM
