Sponsored by: Auxito
brake job???
Old Dec 21, 2001 | 03:45 PM
dship's Avatar
dship
brake job???
I own a 1998 F150 4x4. Having trouble getting front brake rotors off. One dealer said I need to remove large nut with keeper and cotter key and 2 dealers said rotor shoud come off after removing wheel and bracket....Any one ever have this problem of maybe rotor seizing up on hub. THANKS dship
Old Dec 22, 2001 | 09:13 PM
Ultramagdan's Avatar
Ultramagdan
brake job???
The rotor will come off once the wheel is removed. No need to remove the big nut unless you want to remove the axle shaft.
These rotors can be a bear to remove if they have been there awhile and especially if you had it in a harsh environment, i.e. ice/snow.
I would not use heat on it but some serious hammer blows may be inorder.
Old Dec 27, 2001 | 01:51 AM
bufordt's Avatar
bufordt
brake job???
What ever you do use loctite on the brake caliper bolts, mine came loose and the caliper ended up eating the $400 Alluminum wheel. Thank god for junk yards. The tire shop i went two said it wasnt the first time they had seen it happen.
Old Dec 28, 2001 | 10:32 PM
denise_sv650s's Avatar
denise_sv650s
brake job???
I'm am currently trying to take the front rotors off my '97 F150 4x4. I took a break to come inside and see if anyone had posted some suggestions. (Needed to warm up too.) I tried using a hammer on the rotor, but it won't budge. At this point I don't care about saving the rotors. They are too close to the minimum distance spec and I don't think any shop will turn these anyway.
Does anyone have any suggestions?
Thanks.
Old Dec 28, 2001 | 10:56 PM
Triax's Avatar
Triax
brake job???
dship
1997 - 2003 F150
May 20, 2007 06:18 PM
dship
1997 - 2003 F150
Aug 29, 2005 09:32 PM
dship
1997 - 2003 F150
Oct 14, 2002 11:49 PM
dship
15
Sep 29, 2002 12:08 PM
