alternator plug
Old Feb 17, 2008 | 01:11 PM
97-psd's Avatar
97-psd
alternator plug
hey guys, my batt. light came on the other day, and I noticed the volts would drop at idle but would come up at higher rpms, so I had my alternator tested, and had my batteries load tested, and all checked out fine, so I started checking connections and found the single plug connection on the alternator was loose and didn't seem to be making a good connection, but I can't seem to find a replacement plug for it, anyone know where to find one?? and could this actually be caused my drop in voltage??
thanks
Old Feb 17, 2008 | 02:30 PM
IDMooseMan's Avatar
IDMooseMan
Short answer, yes, that could cause the voltage drop.
You could try a salvage yard to get one and splice it on to your rig, but that can cause other problems. As long as the plug isn't melted or otherwise damaged, it should be fine.
There was another person with the same issue. Do a search on "voltage drop" or "alternator" and you should find it. His problem turned out to be a bad alternator, but there was talk about a "clip" or something coming loose that holds the plug in securely.
Old Feb 17, 2008 | 02:49 PM
Cuda_jim's Avatar
Cuda_jim
Yep, pretty common failure due to people laying on top the alternator. You can get a repair pigtail from most mega auto part stores, Autozone, Pepboys ect.
Old Feb 17, 2008 | 02:57 PM
IDMooseMan's Avatar
IDMooseMan
See that, Jim? I am learning from you guys.
Old Feb 17, 2008 | 03:12 PM
97-psd's Avatar
97-psd
I was at advance and they said they didn't have a plug for it, looks like I will have to go and look myself, atleast I know it is a likely cause of my voltage problem, and yes I have been guilty of laying on the motor to work on it , and it is pretty loose, I can pull it off without having to release the lock-tab from the plug, I hope this fixies my problem, thanks for the help
Old Feb 17, 2008 | 03:41 PM
Cuda_jim's Avatar
Cuda_jim
you can try to tighten the connector pins/sockets, the most likely cause of the problem.
The dealer has them for sure but they are very proud of their stuff, last one i bought for a 5.4 triton coil was $23, had to do it, no one else had one.
Old Feb 17, 2008 | 04:13 PM
97-psd's Avatar
97-psd
just out of curiosity, what does the single pin plug do?? the wire form the connector only goes to one of the wires on the three wire connector on top of the alternator, is it part of the voltage regulator??
Old Feb 18, 2008 | 08:41 AM
97-psd's Avatar
97-psd
well it looks like I found my problem, I was checking my connections last night and low and behold I found the bracket that is supposed to be mounted to the gpr relay post that holds one of the coolant lines was leaning against the alternator, and it sparked when I accidently bumped it , apparently when we changed my gpr to a stancor we forgot to re-attached the bracket, and ever since then no more battery light or voltage drops, it's amazing how that works thanks again for all the help
Old Feb 18, 2008 | 05:41 PM
IDMooseMan's Avatar
IDMooseMan
I'm glad you found and corrected the problem.
Old Feb 24, 2008 | 06:20 PM
joe_13894's Avatar
joe_13894
That wire is the stator input to the regulator. It connects to one of the phases of the alternator winding.
The three wire plug goes into the regulator. The gray housing below the plug is the regulator itslef. The regulator bolts directly to the brush holder for the field connection
The stator wire is used to tell the regulator that the alternator is spinning. If full 12V is applied to the field wihtout spinning the alternator, the rotor winding will burn up do to lack of cooling air from the fan. So the regulator won't apply full field until the alternator "picks up."
When the key is turned on, current from the ignition goes through the warning lamp to the regulator. This wakes the regulator. The regulator grounds the lamp circuit turning the light on. It also puts a low current through the field winding. The current is low enough it won't hurt the rotor if it's left on indefinetly. When the engine starts, an AC voltage will appear on the stator wire. This enables the regulator and it will go ahead and turn on full voltage to the field. It also turns off the idiot light feed.
Old Aug 20, 2010 | 05:05 PM
MONAVIERONJON's Avatar
MONAVIERONJON
Would it be correct that if the regulator were bad there would be a constantly grounded circuit via the lamp?
Old Aug 21, 2010 | 11:50 AM
crazy4wdracer's Avatar
crazy4wdracer
There is a place online that sells them...I bought one for mine because there were frayed wires.
Old Aug 21, 2010 | 11:52 AM
crazy4wdracer
This is probably the one you are talking about.
Ford Alternator and A/C Clutch Repair Connector - The Repair Connector Store
MattEich
22
Jan 6, 2016 10:45 AM
jonnygorgo
29
Mar 12, 2014 06:36 PM
Bubba Jones
1978 - 1996 Big Bronco
Sep 17, 2012 12:25 PM
sdetweil
Jun 13, 2008 09:10 PM
mramelbass
Electrical Systems/Wiring
Jul 21, 2004 07:17 PM
