Bilstein shocks
Old Feb 28, 2008 | 11:36 AM
  #31
UP_There's Avatar
UP_There
I would guess it was closer to 5" then 4 1/2" but everybody's truck sits differently. 5" is probably what it was........rode GREAT especially considering the add-a-leaf was in the spring pack. Most will tell you to stay away from that, but at the time.....money was an issue, so I went that route on lifting it.
Old Feb 28, 2008 | 11:40 AM
  #32
sflem849's Avatar
sflem849
What is the difference between an add leaf and a spring pack? I guess I don't understand what makes one worth over twice as much.
Old Feb 28, 2008 | 11:44 AM
  #33
UP_There's Avatar
UP_There
add-a-leaf is just one leaf that you adding to your existing spring pack. A new spring pack is all new leafs. Full replacement.....that's why it's so much more.
Old Feb 28, 2008 | 12:28 PM
  #34
sflem849's Avatar
sflem849
So it doesn't do anything more than the add a leaf does other than take a new Ford spring pack and add an extra leaf? What about the mini packs that clamp into the middle some how?
Old Feb 28, 2008 | 06:14 PM
  #35
ron's power stroke's Avatar
ron's power stroke
there is 2 diff add a leaf..one will up the GVW on the front axel an extra 600lb and the other is 800lb..it also lifts the front of the truck about an 1 1/2"..there for trucks with plows to hold the extra weight..i need it for my front bumper hitch when im pushing a camper into tight spots..
Travis...can you find out how much it weighs and how big of a box it will be??? i'll call around and see who will do this..thanks a lot...
Old Feb 28, 2008 | 06:24 PM
  #36
Mike Norwood's Avatar
Mike Norwood
Weight should be your only issue there, Ron. I worked at Fed-Ex and UPS while in college and we shipped springs all the time with nothing more than a shipping label stuck to them. They will charge you extra because of the weight and shape. Good luck!
Old Feb 28, 2008 | 06:28 PM
  #37
sflem849's Avatar
sflem849
That is what I was going to say. We have a UPS station at work and they never know if it is oversized till it is already in the computer...hmm
I would zip tie them together if they are not over 80 lb (70 is the heavy limit, but they give you ten or fifteen for cheap) Then just stick a label on.
Old Feb 28, 2008 | 06:33 PM
  #38
ron's power stroke
that what I was hoping...if not ship it one by one...
  #39
Mike Norwood
Better use heavy zip-ties there. Those guys do not treat that type of stuff nicely. I know, I know, they say that every package is treated with care. What they don't tell you is the kind of care that it is treated with. When you have seen a box fall from thirty foot and seen guys climbing over boxes you have a tendency to package differently.
Old Feb 28, 2008 | 06:35 PM
  #40
sflem849's Avatar
sflem849
On the upside. They are springy pieces of metal I don't think you could wreck them...w/o doing something REALLY stupid.
Old Feb 28, 2008 | 06:51 PM
  #41
UP_There's Avatar
UP_There
I will get them weighed in a couple days Ron......I'm headed to work tomorrow, back sat night, so I'll give you a rough number by sunday.....then we'll worry about shipping them! I'm about to post pics of the newly installed lift....
Old Feb 28, 2008 | 06:53 PM
  #42
ron's power stroke
thanks a lot Travis..ill check you thread out when you post the pic's
jkarne
2004 - 2008 F150
Jan 5, 2012 10:51 AM
1982_f150
Aug 15, 2011 03:41 PM
Dutter
1983 - 2012 Ranger & B-Series
Mar 1, 2011 12:09 PM
grncoup
Mar 25, 2006 08:12 AM
notsoswwuyd
1978 - 1996 Big Bronco
Nov 1, 2004 10:33 PM
