302 mild upgrade
Old Feb 24, 2008 | 08:08 AM
  #31
baddad457's Avatar
baddad457
Yea. I guess I did.
Old Feb 24, 2008 | 09:51 PM
  #32
Ford347's Avatar
Ford347
perfect I have a 5.8L in a 94 f250 im about to take the engine apart so I can probably use those heads
Old Feb 24, 2008 | 10:35 PM
  #33
doug1222556's Avatar
doug1222556
Unless there is something seriously wrong with those heads, you're golden. You could still benifit by opening up the exhaust ports on those heads, if you are so inclined. You keep messing around, though, and you might accidententally wind up with a badass motor, instead of a little over stock. That all depends on your perspective of performance, though. One man's neck breaker is another's grocery fetcher.
Old Feb 25, 2008 | 05:39 AM
  #34
baddad457's Avatar
baddad457
If you're lucky, that 94 351W will have a roller block. Use that for a buildup.
Old Feb 25, 2008 | 06:18 AM
  #35
rickh51's Avatar
rickh51
Hey Ford347. And to think it all started when you bought a carb and intake! NOBODY can change just one thing. I sure can't! Oh well . . . . . so much for the "mild upgrade." Have fun with it!!
Old Feb 25, 2008 | 10:15 PM
  #36
Ford347's Avatar
Ford347
yeah its great but I have bigger plans for my 351w im thinkin stroker. I just want something for now.
Old Feb 25, 2008 | 10:29 PM
  #37
Ford347's Avatar
Ford347
Would those heads be pedestal or stud mount?
Old Feb 26, 2008 | 03:47 AM
  #38
baddad457's Avatar
baddad457
Pedestal. All the small block production heads after 78 were Pedestal mount
Old Feb 27, 2008 | 10:07 PM
  #39
Ford347's Avatar
Ford347
Thanks for all the info I just cant wait to start on it
Old Mar 20, 2008 | 08:01 PM
  #40
Ford347's Avatar
Ford347
Originally Posted by baddad457
E7's have 64 cc chambers. These came on 87-97 trucks, vans (5.0 & 5.8)and the 87-95 Mustang 5.0's. Also found in the late 80's Lincoln Mark VII 5.0. If you get a set off a 5.8 (351W) you'll need head bolt step washers to use with the 5.0's smaller head bolts.
So what would be better for what im doing bolts with the washers or would the studs be a better choice
Old Mar 20, 2008 | 08:17 PM
  #41
doug1222556
302's use smaller head bolts than 351w's, the step washers help center the bolts on the heads. Studs are usually better than bolts, because of the way they torque the heads down without twisting. The 2 downsides are that they make it hard to impossible to remove the heads without removing the engine in most engine bays and they cost a lot more. I am not sure , but I would think you would want the washers with the studs as well. I don't think they are a have to have option, but highly reccommended.
Old Mar 21, 2008 | 02:58 AM
  #42
Ford347's Avatar
Ford347
who makes bolt kits for this application?
Old Mar 21, 2008 | 05:22 PM
  #43
doug1222556
Mr.gasket, Ford,Pioneer and a few others, but check out ARP (American Racing Products), they are the best, you can find them at Summit Racing .com.
quincyj34
Sep 15, 2015 02:15 PM
Nitesaber
26
Feb 27, 2013 08:51 AM
SoCalExile
Apr 1, 2012 09:44 PM
big-ugly
May 2, 2011 07:27 PM
madrockwyo
Feb 14, 2007 03:57 PM
