302 mild upgrade
Old Feb 16, 2008 | 07:04 PM
Ford347's Avatar
Ford347
302 mild upgrade
I have a 302w in my 78 f100 I recently purchased a 600cfm carb and an intake to go with no im looking for a cam everything else is stock .I dont want to go crazy I just want something to have a little fun with and decent power impovement over stock. Its a daily driven truck with stock converter and gears etc. I was looking at Comp Cams XE250 or 256 or Crane cams Zcam256 will any of these be good for my application? Please Help!
Old Feb 16, 2008 | 09:13 PM
baddad457's Avatar
baddad457
Comp doesn't recommend using these with the stock valvetrain, meaning you'll need new springs, retainers, locks, rockers, pushrods too. A better choice would be one of their High Energy grinds.
Old Feb 17, 2008 | 09:55 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
New heads would be the best money you could spend on that engine.
Old Feb 17, 2008 | 02:08 PM
rickh51's Avatar
rickh51
I used a Comp Cams 268H (K31-218-2) cam and kit when I rebuilt the 302 in my '78. Ran pretty strong. Just buy the whole kit. You'll need all that other stuff anyway! Really don't think I'd trust 30 year old valve springs. Besides, if your motor hasn't been gone through, the valve seals are probably shot anyway. Get new pushrods, they're cheap. As far as rocker arms go, I used Crane Energizer roller rockers on mine, but if yours are in good shape, you could probably reuse them. Check them out real closely for wear!! Anyway, I hope this helps! Like Baron said though, heads would really help! What kind of shape is the rest of the motor in? Compression ok? It's NEVER that easy, is it?
Old Feb 17, 2008 | 03:04 PM
Ford347's Avatar
Ford347
Its the orig motor and it was rebuilt about 7yrs ago in high school eveything is stock except shorty headers. It runs really good dont have any problems with it. I just want a little bit more out of it. I dont have the money for heads right now or much else but I was thinking of pulling the stock ones off and mabey just clean them up and open them up a little. Check valves and seals etc. I might go with the 260H comp cam not sure yet still or crane energizer cam.
Old Feb 17, 2008 | 04:42 PM
baddad457's Avatar
baddad457
You can use the 268H and smaller grinds with the stock valvetrain stuff of an added boost. Not a bad idea to get new springs and the rest, but it's not required.
Old Feb 18, 2008 | 11:40 AM
Ford347's Avatar
Ford347
Will that 268H work with my stock torque converter? Cause im actually thinking on that cam now it sounds good.
Old Feb 18, 2008 | 11:41 AM
Ford347's Avatar
Ford347
has anyone changed the cam bearings without ripping to whole engine apart? Can it be done?
Old Feb 18, 2008 | 07:07 PM
rickh51's Avatar
rickh51
Don't see why you can't use your stock converter, it's not that big of a cam. Comp recommends a higher stall converter if you need one. And they don't for that cam. I have a manual trans in mine, so it didn't matter. Concerning the cam bearings, they're normally replaced when the block is in the machine shop getting hot-tanked. I really don't think you can change them with the engine in the truck. Did you change them when you rebuilt it?
Old Feb 18, 2008 | 07:08 PM
baddad457's Avatar
baddad457
The 268H will be fine with a stock converter. Ditto for th ecam bearings, leave em be. They rarely wear out. They usually got changed in rebuilds cause the old hot tank cleaning ate em up.
Old Feb 19, 2008 | 04:19 PM
Boba Fett's Avatar
Boba Fett
Before you go to all that trouble swapping the cam and pushrods, which is costly and head scratching, I would either get a roller 302 motor from the 80s in that thing or get roller tipped 1.7 rockers to increase the lift of the stock cam and call that a job!
Old Feb 19, 2008 | 05:56 PM
Ford347's Avatar
Ford347
yeah the cam bearings were definetly replaced when it was rebuilt so would I be ok not to change them this go around? I didnt want to take the engine right apart if I didnt have to. I will for sure get pushrods and valve seal and springs cause most of it all comes in the kit anyways.
Old Feb 19, 2008 | 07:00 PM
baddad457's Avatar
baddad457
You can buy the cam and lifters separately too. You don't HAVE to buy all in a kit.
Old Feb 22, 2008 | 11:38 PM
doug1222556's Avatar
doug1222556
You definately ought to open up the exhaust ports on those heads, like you said you were considering. That will give you a big boost in performance and go well with the other changes.
Old Feb 23, 2008 | 12:36 AM
Ford347's Avatar
Ford347
Yeah I dont know if i'll do much on the intake side just the small radius and valve guide boss but deffinetly open exhaust. Got a couple more questions, what length of pushrods are in my engine now so I can get new ones? Also are my rocker arms stud or pedestal? I want to get some roller rockers
