Transmision Oil Cooler
Old Feb 15, 2008 | 07:55 PM
spencer922's Avatar
spencer922
Hi I have a '95 F350 7.3L. A couple months ago I had a transmision oil cooler installed by my local dealer. I have been running 33's and do light offroading. But, I am getting a 4"Tuff Country lift instaled with some 35"s..Then the other day, after scouting out the underbelly of the truck I realized how exposed and vulnerable that oil cooler is. The fan is completely exposed as there is nothing between it and the ground. Its located right behind the tranny, and at the lowest point possible. With 35's I'm not going to be hitting any big pits or anything, but I was wondering if anyone had any ideas on anything to beef this up and keep it a little bit more protected. I was just going to fabricate a little cage to put over it..If anyone has any thoughts on what might be a better idea, its appreciated. Thanks.
Old Feb 15, 2008 | 08:01 PM
95F350XL's Avatar
95F350XL
My trans cooler is infront of the rad. Do you think you could move it, or make a cage around it?
Old Feb 15, 2008 | 08:17 PM
spencer922's Avatar
spencer922
Well, the only reason I could think of that they couldn't is that ther PS doesn't leave a enough room up there for one. I could probably go ask the dealer if they knew of a good spot to put it, or just see if I can find one. The cage idea isn't a bad one, but with it bein in the middle of the truck, and having the crew cab and the long bed I'm kinda nervous about some clearances...I'll try to figure something out.
Old Feb 15, 2008 | 08:29 PM
95F350XL's Avatar
95F350XL
Seeing you have a fan for the trans cooler, can you move it up higher, or into the frame rail somewhere?
71FSB
New Jersey Chapter
Mar 24, 2013 12:11 PM
Mark Buzzard
Jul 9, 2009 09:53 AM
Evan III
1978 - 1996 Big Bronco
13
Sep 16, 2005 12:52 PM
fordbilly
Jan 12, 2005 09:46 PM
mic
Jul 27, 2002 06:45 PM
