TUFF COUNTRY SUSPENSION
align and then have the same response that its hard to get the camber correct,so here's my question.... I was reading about tuff country having their axel pivot brackets with a built in camber adjustment bolt that is suppose to corect and make alignments easier and precise, I was wondering if anyone here has tried or heard of Tuff Country's Suspension and just how good is this axel pivot bracket for alignments really are... any pros and cons would be appreciated.
There going for $169.95 + shipping, so Ijust want to know if they're worth my money and time to install...Tires are really expensive you know.
1993 F-150 Flareside X-Cab
6" superlift
Super Runner Steering System
Super Runner Radius Arms
35" Goodyear MTR'S
15x10 Mickey Thompson Classics
MSD Ignition System
K/N air Filter
4.56 Gearing
Extang Soft Tonneau Cover
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, CD player with 2 10" subs and some 32" BFG Muds
.Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Then theres:
99' Mustang GT 4.6L
but, TOUGH COUNTRY is a different Company, I know people get them confused cuz they sound alike, but, they are different, and I know I have the axel pivot brackets, but, Tough country has on theirs a camber adjustment that goes thru and mounts where the TTB mounts to it, I was just asking if anyone has tried theres and if it was any good.. its similar to the way Toyotas and Chevy adjusts their Camber and makes alot of sense doing it that way due to the numerous alinement problems that the TTB gives us. Using this adjustment, you would never have to mess with the camber bushing on the upper ball joint, but, would just have to turn a eccentric bolt on the axel pivot bracket..so my question was has anyone tried Tough Country or have any friends who has and what was their thoughts...
Maybe the guys working on your truck are the problem.
I also ran a plow on the front in the winter and beat it up pretty good off road.
Super lift is one of the top 3 manufactures of "kits" and thats based on the quality of thier fabricated parts.
Brian
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, CD player with 2 10" subs and some 32" BFG Muds
Then theres:
99' Mustang GT 4.6L
Anyhow... the adjustable bushings that are built into Tough Country's lift for your truck are a good option, they DO make it easy to align... however, they are a weak link if you go wheelin'
It lessens the durability of your front end.
These can loosen and leave you with a wobbly front end!
So it just depends on how much wheelin you do
-Jess
