1978 - 1996 Big Bronco
flexplate help
Old Feb 15, 2008 | 07:49 PM
dragogt's Avatar
dragogt
flexplate help
working on a 302 to 351 swap, but I'm having problems finding a flexplate that fits the 351. (it's a mid 70's model mercruiser engine) I'm on my 3'rd one from O'reilly and it doesnt sit all the way back on the crank, it only go's about half way and stops. Any idea's, tips, or tricks would be appreciated.
tks drago
Old Feb 15, 2008 | 08:52 PM
Bimmerboy1989's Avatar
Bimmerboy1989
Get a bigger hammer?
Old Feb 15, 2008 | 09:02 PM
dragogt's Avatar
dragogt
trust me it crossed my mind, but I don't wont to screw any thing up. Also thought about drilling the holes out a little, but I don't think I should have too.
Old Feb 16, 2008 | 06:55 PM
dragogt's Avatar
dragogt
come on guy's, I know somebody in here knows the answer to this.
Old Feb 16, 2008 | 08:56 PM
Bimmerboy1989
So is the flexplate you have tried a 351C Flex plate, a 351W flex plate or a 351M flexplate? Can you give me the part number of the flex plate they have given you? FRA201? or FRA205? When I go to work tomorrow I will try and post some possible flexplates.
Old Feb 16, 2008 | 08:57 PM
Bimmerboy1989
Oh, What kind of transmission is it hooking up to, and what motor was it? a 351C, 351W, or 351m?
Old Feb 16, 2008 | 09:14 PM
dragogt's Avatar
dragogt
it's a 351W hooking up to a C6 and a 302 coming out of my bronco.
started out w/ fra-203 then went to fra-205 and last but not least I got fra-201 which fits the best but's still not right.
Old Feb 16, 2008 | 09:17 PM
Bimmerboy1989
Ok, I will see what I can come up with tomorrow.
Old Feb 16, 2008 | 09:18 PM
dragogt's Avatar
dragogt
cool man thanks.
Old Feb 17, 2008 | 08:42 PM
Kemicalburns's Avatar
Kemicalburns
what year is the 351w motor? if its pre 82 then it would be the same imbalance as the 302 if the 302 was pre 82 as well. so you could use the 302 flexplat on the 351w. if that doesnt fit then you dont have a 351w.
Old Feb 17, 2008 | 09:07 PM
dragogt's Avatar
dragogt
it's a '74 block Mercruiser used between '75-'77. https://www.ford-trucks.com/forums/6...ne-pt-2-a.html
I thought that in '83 ford switched to the 50oz imbalance?
Old Feb 18, 2008 | 09:53 AM
toolman's Avatar
toolman
How close to they actually get ? I've got a block out of a Galaxie which used an ever so slightly thinner flexplate, along with a thin stiffener plate. ( Thanks again Number Dummy !! )
Just a thought !
-Scott in Spokane
Old Feb 18, 2008 | 10:00 AM
dragogt's Avatar
dragogt
if you mean plate to block, it's still about a 1/2" away from seating in place.
like I said I'm open to any and all Ideas.
tks, Drago.
Old Feb 20, 2008 | 02:23 PM
Bimmerboy1989
I'm sorry it took a few days for me to get back. I found that a 79 Ford pickup with a 351w and a C6 transmission takes a fra-202 flexplate. This flex plate should fit what you have.
Old Feb 20, 2008 | 02:36 PM
dragogt's Avatar
dragogt
no worries, know haw things can get busy, appreciate the reply I will go take the one I have back and get the 202. Will post back w/ results.
