Anodized Trim Cleaning
Old Feb 18, 2008 | 05:50 PM
  #31
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by psquare7575
This search function is no more difficult than any other forum's. My friends 9 year old kid can use it.
It isn't that it is difficult to use, it is just pointless.
Old Feb 18, 2008 | 05:54 PM
  #32
Bullitt390's Avatar
Bullitt390
https://www.ford-trucks.com/forums/4...shing+aluminum
Good luck finding that in the APPEARANCE forum.
Old Feb 19, 2008 | 09:11 AM
  #33
FTE Ken's Avatar
FTE Ken
Folks... lets get back to tech discussion. Dennis has been warned about trying being FTE's net-nanny more times than we can count and has been giving some time to cool-off.
Old Feb 19, 2008 | 02:51 PM
  #34
FTE Ken's Avatar
FTE Ken
Okay folks, I've cleaned up this thread so it can get back on topic.
Old Feb 19, 2008 | 03:26 PM
  #35
Sgt Wonderful's Avatar
Sgt Wonderful
Thanks Ken
Old Feb 19, 2008 | 03:37 PM
  #36
masterbeavis's Avatar
masterbeavis
Here is another iron to throw into the fire.
How do you restore damaged dinged nicked trim, and get it to look like the rest of the piece. I have some trim that is from super camper specials, and crew cabs that are damaged, would like to fix em up and not damage the surface, or at least restore it to an OE look.
Old Feb 19, 2008 | 05:20 PM
  #37
ArcadeTom's Avatar
ArcadeTom
[QUOTE=kuzzins27]Article - "How to Clean and Polish Anodized Aluminum" http://www.secondchancegarage.com/public/665.cfm[/QUOTE]
Excellent article. Thanks for the posting...now if I can just find a tray large enough for those trim pieces on my eight foot bed....
Old Feb 19, 2008 | 05:21 PM
  #38
kuzzins27's Avatar
kuzzins27
Tall garbage can. Do one side, then flip over and do the other.
Old Feb 19, 2008 | 05:22 PM
  #39
masterbeavis
[QUOTE=ArcadeTom]
What, the bathtub in your house isn't big enough??
Old Feb 19, 2008 | 05:24 PM
  #40
ArcadeTom's Avatar
ArcadeTom
[QUOTE=masterbeavis]
LOL....it might be, but I was trying to avoid the fumes from all the cleaner affecting me or the cat.
Old Feb 19, 2008 | 05:40 PM
  #41
Sgt Wonderful
I once built a frame out of 2x4's and put Aluminum foil in the frame. It worked out great. You can build any shape or size you want. After all how many times are you going to use it.
Old Mar 7, 2008 | 08:11 PM
  #42
cmpd1781's Avatar
cmpd1781
(DELETE POST)
Old Mar 7, 2008 | 09:27 PM
  #43
sierraben's Avatar
sierraben
Interesting thread here.
I did find good info on "How to Clean and Polish Anodized Aluminum".
Old Mar 21, 2008 | 12:42 AM
  #44
curt meyer's Avatar
curt meyer
If your trim is very faded ,clear epoxy carefully aplied (Dont get it on your paint) will make it look new. It even takes out scratches.
Old Mar 21, 2008 | 06:33 PM
  #45
dano44639's Avatar
dano44639
i just did this, using an 8 - 10 inch polishing wheel on a drill and use the black emery compound. Tape around the paint using blue painters tape. clean up with soap and water. if that doesnt work sand the finish using 320 wet sandpaper, then use black emery compound. you will need to polish the trim once the finish is removed. you can use vinegar to remove the stubborn spots.
