how to tell if timing chain jumped tooth
Old Feb 15, 2008 | 04:00 PM
albung's Avatar
albung
Any way of telling short of pulling timing cover?
Old Feb 15, 2008 | 04:10 PM
85e150's Avatar
85e150
Rotate engine to TDC on number 1 using timing mark on balancer, check number one to see if at TDC. You need a piece of stiff wire in the plug hole to feel the piston movement.
If it jumped a tooth, it is very loose. To see how loose, pull the distributor cap. Rotate engine by hand until the rotor moves. Then reverse the rotation by hand and see how far you have to turn the crank before the rotor moves. More than a few degrees means wear (some of which is normal, it's going to wear) and more than 1/8th turn means BEware, 1/4 turn means start pulling it apart.
Seriously, I'm not sure what the tolerence is for slop. 1/8th turn sounds like too much to me.
Old Feb 15, 2008 | 04:54 PM
flareside_thunder's Avatar
flareside_thunder
VERY good advice....
JR
Old Feb 16, 2008 | 11:25 AM
quisp-n-quake's Avatar
quisp-n-quake
Yea,..- what 85e150six4mtod said is pretty much on the money,..The Haynes manual will tell you pretty much the same thing, and if the chain is wicked loose,- you might want to inspect the inside of the timing cover as well because the chain slap will tear up the inside of it, and possibly make a real thin area on the cover which will be prone to a crack and leak.
Old Feb 16, 2008 | 12:02 PM
flareside_thunder
Upgrade it to a double roller anyhow...it helps prevent a tooth jump in the future....
JR
Old Feb 16, 2008 | 12:22 PM
ned37's Avatar
ned37
put a timing light on it after pulling the spout connector. if jumped, it will be waaay off.
Old Feb 16, 2008 | 12:32 PM
flareside_thunder
heh...NED that's too easy man...gotta do things the old school way lol.
JR
Old Feb 16, 2008 | 12:34 PM
albung's Avatar
albung
it wont run so be hard to test with light. I think its something else play is minimal when turning balancer and watching rotor
Old Feb 16, 2008 | 12:55 PM
quicklook2's Avatar
quicklook2
why the no start?
why suspect the timing chain?
Old Feb 16, 2008 | 12:57 PM
netscaner's Avatar
netscaner
HUH....................................??????????? ???
The relationship of the balancer to TDC has nothing to at all to do with the timing chain.
A jumped or broken cam timing chain has nothing to do with the harmonic balancers relationship with the crankshaft.
Old Feb 16, 2008 | 01:11 PM
ned37's Avatar
ned37
if it won't run, bump it around to the tdc timing mark on the crank and pull the dist cap. if not jumped, the rotor should be pointing right at #1 plug wire. if 180* out, turn the crank another rotation. if off a tooth or more, it'll be fairly obvious.
another thing that could have happened is the pin locating the dist gear has sheared or come out.
Old Feb 16, 2008 | 01:40 PM
albung's Avatar
albung
Ya thats what i tryed all looked good. I seem to have a severe flooding problem. I now seem to get intermittant spark.
Old Nov 28, 2023 | 10:58 AM
69fairlane's Avatar
69fairlane
1st Gear
Resurrecting the dead here lol. Do you recall how you fixed this? Mines doing the same thing
Old Nov 29, 2023 | 02:43 AM
tpctec's Avatar
tpctec
Could be the 10 cent roll pin split that holds the distributor gear on letting it move. Did a timing chain set one time for that. when you remove the cap and look at the slop while turning the crank it appears like the chain is lose but it could be the roll pin.
Old Nov 29, 2023 | 06:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
he last logged on 5-5-2008
mxer0022
Apr 21, 2015 04:35 PM
302Meister
Feb 10, 2015 01:40 PM
billybobzia
2009 - 2014 F150
Jan 8, 2014 02:11 PM
2 stroke man
174
Jun 2, 2009 09:34 PM
Dave Carney
Nov 10, 2005 09:54 PM
