Van turbo?
Old Feb 14, 2008 | 02:13 PM
C350CREW's Avatar
C350CREW
Van turbo?
I read somewhere that a van 7.3 turbo is bigger than the pu? anyone know if this is true?
do parts from the newer 7.3's fit our models, (turbo, starters, alt., tranny, etc)?
Old Feb 14, 2008 | 02:19 PM
secondarychaos's Avatar
secondarychaos
The van turbo exhaust housing is bigger, so that it doesnt need a wastegate. its supposed to be a good upgrade to put the van's exhaust housing on the truck turbo, but you need an adaptor.
someone else can chime in w/ more info im sure...
Old Feb 14, 2008 | 02:53 PM
MADVAN's Avatar
MADVAN
Van turbo is 110/115 ar
Bill
Old Feb 14, 2008 | 04:13 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Why worry about it? The main issue with the Powerstroke turbos (94-03) is that the 99.5-up trucks' turbochargers are prone to surge mostly due to the crazy speeds that extra fuel cause the turbine to spin. A larger turbine housing is the answer for those turbos.....and the van turbo (the turbine housing) is what those folks use. Your old body style (94-97) turbocharger already has the same size (basically exhaust flow) turbine housing already. You won't notice a whole lot (read: no) of improvement.
Old Feb 14, 2008 | 04:50 PM
MADVAN's Avatar
MADVAN
Yep!
Same as adding a WW.
You allready have it.
Bill
Old Feb 14, 2008 | 05:48 PM
tjbeggs's Avatar
tjbeggs
The OBS van and pick up turbo's are the same. The turbo info above only pertains to the 99-03 engines. The adapter that is needed exhuast housing outlet where the downpipe attaches.
Old Feb 15, 2008 | 09:33 AM
C350CREW's Avatar
C350CREW
I have access to some retired 90's 7.3 ambulances, do they have any parts of value that will fit my year?
Which factory intercooler is better, the 7.3 or 6.0? Did i read in another thread that the piping won't work, would have to get a kit from Banks?
by the way, is there anything you guys don't know about ford trucks??
THANKS for all the info and help!!!!!!!!
Old Feb 15, 2008 | 09:58 AM
tjbeggs's Avatar
tjbeggs
Yes if the abulances have the 215 amp alternator those make for a nice upgrade for out truck!! You could send one to me as well!!
The 6.0 IC is better since its bigger. Piping can be made from 7.3 superduty piping and an early 99 intake y-pipe.
https://www.ford-trucks.com/forums/6...installed.html
http://members.localnet.com/~boys3/
Old Feb 15, 2008 | 10:01 AM
secondarychaos
[QUOTE=tjbeggs]Yes if the abulances have the 215 amp alternator those make for a nice upgrade for out truck!! You could send one to me as well!!
http://members.localnet.com/~boys3/[/QUOTE]
What are our stock alternators?
Old Feb 15, 2008 | 10:04 AM
ono_55's Avatar
ono_55
they are 130 amp
Old Feb 15, 2008 | 11:02 AM
MADVAN's Avatar
MADVAN
As Tj states 215.
Also dual alts were available.
Bill
Old Feb 15, 2008 | 02:15 PM
C350CREW's Avatar
C350CREW
Sounds great. this guy gets all the local ambulance's, dont' know how many are deisel.
if there are several available, i will let you guys know, most stuff he lets go dirt cheap.
read the thread on the ic, since you lose boost with the ic wouldn't a water injector do as good? I don't do alot of towing, just now and then, sounds like it would be better to keep as much boost as possible and use the w/i to keep egt's down???
Old Feb 15, 2008 | 02:31 PM
secondarychaos
The only thing (as i understand it) is that With an intercooler, you are just cooling down the air. so while the pressure isnt as high, you are still packing approximately the same amount of air into the chamber. this also means it will expand more than the same vol/pressure of hot air.
I am not very familiar with the water injection... so i cant compare it.
