Foil Delete
Old Feb 14, 2008 | 06:43 AM
Izzy351's Avatar
Izzy351
Here's the thing with that. You're not going to pick up much heat from under the hood because after going through the turbo, the air is heated. Under heavy boost, we're talking over 200*. After the intercooler, it's dropped to something like 120*. And don't forget that the **COLD** side I/C pipe is not insulated. That one is much more prone to pick up heat than the other because the air is much cooler, relatively.
Besides, it has been confirmed that Ford did it because of complaints of turbo noise from customers.
Old Feb 14, 2008 | 07:25 AM
Clint40's Avatar
Clint40
I like the foil delete mod. Mine sounds great plus I polished my tube when it was off and it looks nice too. I do agree it was a pain to take off foil but I was doing my glow plugs and UVC connector mod so I thought what the hell whats another hour or so.
Old Feb 14, 2008 | 07:47 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Ok, I didn't know weather I would do it or not. You guys talked me into it. I am doing my auto hub grease job this weekend, so I will do that too. I should like the added shine under the hood.
Old Feb 14, 2008 | 07:51 AM
1996pwrstrk's Avatar
1996pwrstrk
I did mine about a year ago and I think it sounds neat with the WW . I just polished mine with a SOS pad ,after using WD40 , and lacquer thinner to remove the glue.
Old Feb 14, 2008 | 09:04 AM
greedy737's Avatar
greedy737
What are some of the ways to try to get the foil off the pipe, or should I say, what did you's do to get it off????
Old Feb 14, 2008 | 09:11 AM
1996pwrstrk
I just peeled off what I could by hand then soaked it with WD40 and let it sit and work the nasty stuff off a little at a time finished up with lacquer thinner and a rag.
Old Feb 14, 2008 | 09:18 AM
powerstroke1869's Avatar
powerstroke1869
let me dig up my pics quick....
Old Feb 14, 2008 | 09:22 AM
powerstroke1869
ok its not letting me copy right now if anyone can get it out of my gallery and post it on here then we can see them
Old Feb 14, 2008 | 09:45 AM
03_PSD's Avatar
03_PSD
i did this mod about three weeks ago and still haven't listened to the radio. LOVE THE SOUND!!
Old Feb 14, 2008 | 10:25 AM
miller_feed
Let me try. Looks good Bob.
Old Feb 14, 2008 | 10:27 AM
03_PSD's Avatar
03_PSD
man that does look good, nice touch Bob.
Old Feb 14, 2008 | 10:29 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Wow!! That looks really good all painted up. What kind of paint did you use on the tubes?
Old Feb 14, 2008 | 12:55 PM
  #28
a-rod's Avatar
a-rod
On mine I just used 500 degree Duplicolor engine paint from autozone. I did my tube ford red.
Old Feb 14, 2008 | 01:00 PM
  #29
powerstroke1869
thanks guys and thanks for puttin the pic on here.. i got the paint from advance auto parts and i think that its rated for 1200* just make sure that you get a cermaic paint. i think mine was a ceramic block paint.
Old Feb 14, 2008 | 01:26 PM
  #30
ron's power stroke's Avatar
ron's power stroke
did mine in candy apple red dupont auto paint a year ago..hasn't burnt off yet..but putting them in without scratches is another story...
