Is this axle wrap?
Old Feb 12, 2008 | 11:14 PM
F0rdF0rever's Avatar
F0rdF0rever
Is this axle wrap?
When I turn the truck the rear end vibrates and then goes away when I straighten out. It sort of feels like its hopping. Its worse with speed. Is this what they call axle wrap?
Old Feb 12, 2008 | 11:25 PM
khadma's Avatar
khadma
Carpenter Local 745
Axle wrap usually happens under hard acceleration ( wheelspin, burnout, smoking the tires). Mostly when tires lose all traction - The leaf springs will form an S shape - axle wrap. It does cause hopping, are you spinning the tires at the time of hopping?
If not you may have to check your rear diff, brakes or bearings.
Is the rear end a LS diff? (limited slip)
Please list truck info too.
Old Feb 12, 2008 | 11:37 PM
F0rdF0rever
Darren, I updated the sig with some info on the truck. The brakes and bearings are fine as far as I know. All replaced recently. The tires do not spin when it hops.
Old Feb 12, 2008 | 11:55 PM
khadma's Avatar
khadma
Carpenter Local 745
The LS diff has to "release" a wheel while turning - Like an open diff.
I could be your LS is not working properly, or the driveshaft is binding.
I can't tell you for sure, someone else maybe able to help you if they had a similar problem. At least you know what axle wrap is!
Old Feb 13, 2008 | 04:16 AM
RubberDuck's Avatar
RubberDuck
I say the LS in the rear end is "chirping". That's what happens when you change the diff fluid and don't add the friction modifer. Have you had the diff serviced recently? If you have, try adding friction modifer and see if it goes away. And FYI, if you do add the modifer DON'T GET ANY ON YOU!!!! You think gear oil smells bad..........wow. And it will stay on you for 2 or 3 days, no matter how much carb cleaner you use and hand cleaner, showers.......it stays. If you haven't had the diff serviced, I would take this opportunity to pull the cover and give it a look. And No, that is not axle wrap.
Old Feb 13, 2008 | 06:57 AM
MADVAN's Avatar
MADVAN
X2
First sign of failure is after a hwy run the rear will bang making the first turn (turning off ramp) or so off the hwy.
If an additive issue. Install the additive then go do some left/right circles with some figure 8's with the diff up to temp.
99% of the time the LS is to soft (unlocks to easy)
Reverse of your problem.
Bill
Old Feb 13, 2008 | 09:47 AM
Todd525's Avatar
Todd525
x3 for the fricition modifier. Add a botle and make sure that your topped off as well. I have heard this happen with low fluid also, although I dont know for sure that I believe that. But DEF friction modifier. Any parts store sells it.
Old Feb 13, 2008 | 10:15 AM
F0rdF0rever
Thanks guys. I just changed the fluid and added the modifier a few months ago when I did the 08 diff. cover. Ill pull the cover off and inspect it.
Old Feb 13, 2008 | 01:35 PM
caseydudem's Avatar
caseydudem
If you add too much friction modifier could that keep you LS from locking up?
Old Feb 13, 2008 | 01:45 PM
MADVAN's Avatar
MADVAN
Yes. It will unlock to easy.
Bill
Old Feb 13, 2008 | 01:50 PM
nelstone74's Avatar
nelstone74
It could be from the rear shackle flip mod somehow binding. I first check for wear on the shakle or pins and use a jack to cycle the suspension looking for smooth travel
Old Feb 13, 2008 | 02:00 PM
caseydudem's Avatar
caseydudem
Bill
Is there anyway to check this or do you just have to relpace the fluid?
Old Feb 13, 2008 | 02:03 PM
MADVAN's Avatar
MADVAN
Unlocking to soon could also be from worn clutch pack.
If its from to much additive. You have to dump it.
Bill
Old Feb 13, 2008 | 02:08 PM
caseydudem's Avatar
caseydudem
That leads to anther good question. How long do these clutch packs last normaly?
Old Feb 13, 2008 | 02:13 PM
MADVAN's Avatar
MADVAN
Its all in a roll of the dice on that one.
No 2 use the truck the same way.
Bill
