23 Throttle sensor out of range or throttle set too high - TPS
67 Park/Neutral circuit fault - PNP -- Transmission Manual Lever Position (MLP) sensor circuit - Transmissions
52 Power Steering Pressure Switch/circuit open - PSP -- (R) Did you turn wheel during test ?
89 A4LD - Converter Clutch Override solenoid - Transmissions
86 2.3L or 2.9L Truck - A4LD 3/4 shift solenoid - Transmissions (You don't have one of those)
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
Most of these codes are for items not found on your Van Pablo, so I would say that would cause your codes.
