Aerostar Ford Aerostar
Pulled stored codes.....
Old Feb 12, 2008 | 10:57 AM
Pablo-UA's Avatar
Pablo-UA
No CE light, no any problem, but pulled codes for mounth and got
23
67
52
89
86
95
No current codes. Strange.....
All work well.
Cleared this morning and still have no codes.
Old Feb 12, 2008 | 06:39 PM
93nighthawk's Avatar
93nighthawk
23 Throttle sensor out of range or throttle set too high - TPS
67 Park/Neutral circuit fault - PNP -- Transmission Manual Lever Position (MLP) sensor circuit - Transmissions
52 Power Steering Pressure Switch/circuit open - PSP -- (R) Did you turn wheel during test ?
89 A4LD - Converter Clutch Override solenoid - Transmissions
86 2.3L or 2.9L Truck - A4LD 3/4 shift solenoid - Transmissions (You don't have one of those)
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
Most of these codes are for items not found on your Van Pablo, so I would say that would cause your codes.
Old Feb 13, 2008 | 12:20 AM
Pablo-UA's Avatar
Pablo-UA
I suggest ROM swap caused so strange codes. Cleared all, no codes now...
RustyTrustyF150
1997 - 2003 F150
Apr 21, 2017 09:53 PM
griggssteve
2004 - 2008 F150
Jan 10, 2017 07:32 AM
strokenboost
Modular V8 (4.6L, 5.4L)
Aug 22, 2016 09:49 AM
henryFord460
21
Jul 1, 2016 02:40 PM
jonrjen
6.7L Power Stroke Diesel
Nov 7, 2013 08:03 PM
