Sponsored by: Auxito
Replacing ujoints
Old Feb 11, 2008 | 10:48 AM
Manitoulin's Avatar
Manitoulin
Replacing ujoints
I have a bad ujoint, so i am just going to replace all of them with ones with grease fittings. Anyone have any suggestions on what brands that work good?
Old Feb 11, 2008 | 04:20 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
Dana/Spicer or Neapco!
Old Feb 11, 2008 | 04:48 PM
DanK5's Avatar
DanK5
If you only have 1 thats bad, then you only have 1 thats bad. You may go another 80k on the other joints.
Old Feb 11, 2008 | 08:33 PM
steve(ill)'s Avatar
steve(ill)
if you take out the rear drive shaft, then do both ends. doing the front is an option, not a requirement, but not a bad idea. front dont get the same load as the rears.
Old Feb 12, 2008 | 07:57 PM
Beast12's Avatar
Beast12
I had a bad u-joint in the front of my truck about a month ago. I believe they were the originals. One of the cups seized up. So, I replaced all the u-joints (2 front and 2 back) with ones that had grease nipples. Just make sure you grease them! I prefer every oil change.
-Matt
Old Feb 12, 2008 | 09:46 PM
Ultramagdan's Avatar
Ultramagdan
Some of the aftermarket ujoints (NAPA) you cannot grease without dropping the driveshaft. Unless you have a adaptor that will fit inside the tight yoke.
Old Feb 12, 2008 | 10:35 PM
z 97ford1's Avatar
z 97ford1
I replaced mine with fittings and now they are so predictable. Grease them and they keep right on going.
Have not had a problem since.
Old Nov 22, 2012 | 11:05 AM
scottperkins's Avatar
scottperkins
I have a 2000 F-150 and am hearing a rumble at between 442 and 52 mph.
Even though the u-joints seem tight I am going to replace them because
it is something I can do relatively cheaply. Question is what auto
supply store sells u-joints that have grease fittings and are easily
serviceable ?
I really hope the problem is the ujoints or I am up a creek without much
money.
Old Nov 22, 2012 | 11:24 AM
BlueOvalFitter
Thumbs up
serviceable ?
money.
442 MPH!
AAP,NAPA,or Carquest are your best auto parts stores to get grease zerk u-joints.
TIP; make sure you install the u-joint to where you have access to the grease zerk!
Old Apr 14, 2014 | 04:12 PM
DanK5's Avatar
DanK5
Originally Posted by BlueOvalFitter
442 MPH!
YUP!
Old Apr 16, 2014 | 10:17 AM
scottperkins
AAP, NAPA,or Carquest are your best auto parts stores to get grease zerk u-joints in his TIP.
Dan pretty much said to avoid the NAPA u-joints
"TIP; make sure you install the u-joint to where you have access to the grease zerk!
(Some of the aftermarket ujoints (NAPA) you cannot grease without dropping the driveshaft. Unless you have a adaptor that will fit inside the tight yoke."
I know what Carquest is but I dont know what auto parts stores carry their parts ? Who sells AAP parts? I am not familiar with AAP brand.
Thanks
Old Apr 16, 2014 | 02:16 PM
fordcrzymike's Avatar
fordcrzymike
Thanks
I'm pretty sure he means Advanced Auto Parts
Dean06919
Jul 26, 2016 09:28 PM
ggwash21
2004 - 2008 F150
Sep 11, 2013 04:16 PM
Jeremiahcf
1966 - 1977 Early Broncos
18
May 16, 2012 12:15 PM
fordor
Oct 22, 2006 11:41 AM
