429 or 460?
Old Jul 26, 2000 | 04:36 PM
jkt's Avatar
jkt
429 or 460?
i have both a 429 and a 460
the 429 is a stock 2v, and the 460 have an edelbrook manifold and 4v carb, i wanted to know what be the best engine for a 79 bronco with a C6 trannie, this bronco will be used for playing on the weekend. p.s. dont alot of money into them yet
Old Jul 27, 2000 | 07:18 PM
Steve_Uzi's Avatar
Steve_Uzi
429 or 460?
460 for Torque/climbing Longer stroke 3.85 inches ... 429 for Speed/ mud shorter stroke 3.59 means higher revs. = speed
I would recommend Comp Cams Extreme 4x4 Cams.. I had one put in my 460.. engine goes in my 84 Fullsize bronco Monday... can't wait to fire it up!
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
Old Jul 28, 2000 | 11:54 PM
Paul Williams's Avatar
Paul Williams
429 or 460?
JKT...... Just depnds on what you want to do once the engine is in the Bronc..... Both will develop great torque but the 460 will develop more....The 429 will be a little more rev happy..... I have one in my '74 3/4 ton 4x4 and am fairly happy w/ it.... Will turn the tires into white smoke and melted rubber but I have driven similar trucks to mine w/ 460's that would out pull it and they had stock engines..... Mine has a few mods; Cam,intake,carb...thats about all... Either way you go ...In something like a bronco it will be FUN.......... Paul
Old Aug 3, 2000 | 08:47 PM
TBirdGuy's Avatar
TBirdGuy
429 or 460?
What I would do is go with the 460 if it were me. I follow the age old saying, "No Replacement for Displacement." You aren't going to rev a 460 to the brinks that you would a 429, but think about it......Do you REALLY want to rev a big block up that high anyway? That's how I made my desicion as to what motor to put in my car (I realize this is a truck site, but this site rules and I have to come here even though I don't own a truck yet). As far as Hi-perf. parts, I would go with an Edelbrock Peformer Intake and a cam that matches the Edelbrock Performer Cam just not an Edelbrock Cam. I have heard that Edelbrock cams wear out faster and don't give as much performance power as they should. I personally like Comp. Cams, but have heard good things about Blue Racer's & Wolverine's. Good luck with whatever you do man.
Rob
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old Aug 3, 2000 | 10:46 PM
TBirdGuy's Avatar
TBirdGuy
429 or 460?
Old Apr 20, 2005 | 12:35 AM
snotwilim's Avatar
snotwilim
As far as concern about revs, I'd have to agree with Tbirdguy. Both of these engines have done their best work by about 4000 RPM. Reving any further wouldn't yield much. The extra stroke of the 460 will come in quite handy for truck use.
Old Apr 20, 2005 | 12:57 AM
discman's Avatar
discman
How bout getting a 390? hehehe
Old Apr 21, 2005 | 01:05 PM
Brad Johnson's Avatar
Brad Johnson
Unless you intend to build an all-out race motor the extra smidgeon of RPM potential in a 429 is a non-issue. Take the extra 30 cubes.
Brad
Old Apr 21, 2005 | 11:37 PM
shakerag's Avatar
shakerag
no question here...
Locate a 71' Mark III Continental which was 365hp (and the deck height was not changed until the 72 came out). Choose the cam of your choice and rebuild the heads for sure and all the clean up work it needs in the bottom end then top it with a 750 Holley,headers and you will be happy!
Shakerag
Old Apr 22, 2005 | 12:02 AM
351M's Avatar
351M
You could do a 460 with 429 heads, that will up the power in the 460 a bit.
Old Apr 22, 2005 | 01:13 AM
monsterbaby's Avatar
monsterbaby
351m year for year the 429, and 460 had the same heads with the exceptions of the scj (DooE-R casting number), and the boss 9 both of which are a different animal all together, and since the 429 is a 2v it's just a passenger car engine not one of the high perf engines.(BTW all the 460s had 4v carbs unless someone changed intakes trying for fuel economy or something) The early castings will have a smaller combustion chamber, and thus will give a little more compression but for the most part stay away from the 72 castings as were open chamber and really prone to detonation so not a good choice.
Now there are some good recommendation here such as the comp cams xtreme 4x4 cams I have used them in a couple of engines, and they are a really good grind for a truck, but I wouldn't bother with the performer intake, go with a performer RPM you will be much happier for not much of an increase in cost. The performer won't make much more of a difference than the stock 4v intake.
429thunderjet93f350
Mar 26, 2015 10:46 AM
highoctane74
Mar 6, 2011 11:50 PM
79 250 Supercab
Nov 23, 2003 10:50 PM
Wishbone
Dec 27, 2002 08:08 AM
1972 Ford Thunderbird 429 V8
Nov 21, 2002 06:04 PM
