Sponsored by: Real Truck
Front end Bottoms out
Old Feb 12, 2008 | 08:39 PM
Rocky Mountain Jeff's Avatar
Rocky Mountain Jeff
yes I hope to be able to have ford do something but I am not to optimistic on that. If I have to do the upgrade I will and most likely change out the shocks all around at the same time. I have to get all the little things out of the way and then I think I will have a good(better) truck,but still not as good as my 03 was. thanks guys
Old Feb 17, 2008 | 07:06 AM
Rocky Mountain Jeff
A fellow I work with suggested I look to see if there is a variable rate spring I could use. If I understood him correctly the spring would give the smooth ride until it is put under load. His other suggestion is like rotun's suggestion of a leveling kit. I pull a 24ft travel trailer in the summer would the leveling kit alter the way I pull the trailer I run with the reese ball hitch with the bars and sway control. Any thoughts on these two suggestions
Old Feb 17, 2008 | 07:38 AM
Magoo22's Avatar
Magoo22
I think that you will find the variable rate spring will give you a decent ride and prevent the bottom out problem. Kevin at HRT in Okotoks is good wth the Ford SD supensions. He is a Dodge man at heart but I try not to hold that against him. He is actually just south of Black Diamond on Hwy 22. Here is a link to his web site and contact information.
http://highrollerztrux.com/contact-phone.htm
I do not have any interest in HRT but have been a customer and would highly recommend their services.
Let me know if you need any more information.
Good luck
Grant...
Old Feb 17, 2008 | 07:48 AM
Rocky Mountain Jeff
Thanks Grant I will contact Kevin this week. Jeff
tiopet
Feb 26, 2020 06:50 PM
pat420swed
24
Jul 3, 2016 09:20 AM
ExPACamper
Mar 30, 2016 01:05 PM
hot-rod
Mar 7, 2016 10:20 AM
powerstroker02
15
Jul 25, 2011 08:48 PM
