Over sensitive steering 99 Exp
Old Feb 20, 2008 | 10:01 AM
Byron43's Avatar
Byron43
Buzzard sorry about the name error
Old Feb 20, 2008 | 10:23 AM
Byron43's Avatar
Byron43
Outlawspeeder88: I imagine it powers on higher speed reducing the orifice and therefore reducing the hydraulic pressure making it stiffer. On mine at high speed it malfunctions and goes back to wide open causing a dangerous situation. This has happened three times in the last 2 months.
Old Feb 20, 2008 | 07:22 PM
Taumac's Avatar
Taumac
I agree... I have a 99 EB 4x4 always wonder what hell it is? Its right above universal joint on the steering staff under the dash its a ring with holes and looks like something like a pick up sensor. Sensor has 4 wires coming out of it (red, yellow, green, and black) to I guess measure steering input wonder if it work with speedo to control the variable streering? Doea anybody know what it is?
Old Feb 20, 2008 | 07:46 PM
Taumac's Avatar
Taumac
I agree Its right above universal joint on column its a ring with holes and I red looks like infared sensor that reads streering input wonder if it works with speedo to control p/s...... I decided to get froggy pull It out part num reads XL1A-3F818-AA 020U92 and also reads on it Control Devices.inc?????
Old Feb 20, 2008 | 09:58 PM
Byron43's Avatar
Byron43
Taumac I don't know what that part is, but I am going to ck it out. Come to think of it a few months ago I was under there tightening the gear shift shaft that was loose and maybe I knocked what you found out of alignment and my steering problems started after that.
Old Feb 21, 2008 | 10:51 PM
Taumac's Avatar
Taumac
found out its a Shock Asborber Electronic Steering Sensor apparently it senses sharp movement in steering wheel and sends signal to shock motor to stiffen shocks.... waiting for reply back from Y2K ford to tell me if its on Expys with 4 wheel air only and how it works
Flivver250
Dec 12, 2015 12:06 PM
nlareau
Dec 4, 2011 12:11 PM
Butl85
Apr 16, 2011 10:52 AM
48' fordster
Feb 6, 2010 03:17 AM
racer19
May 4, 2009 06:17 PM
