hood guide
Old Feb 10, 2008 | 07:38 AM
m78's Avatar
m78
hood guide
Found this on a 79 bronco at a p-n-p.I haven't ever seen it before but looks like it would keep the hood steady while bouncing around
Also found a tow hook
Old Feb 10, 2008 | 08:02 AM
Jmudder79's Avatar
Jmudder79
I've only seen one of them in many years of junkyarding. Was that a factory option or something aftermarket?
Old Feb 10, 2008 | 09:06 AM
m78's Avatar
m78
The cowl on my 250 was dimpled where the holes were to be drilled for the rivets.The hood was not dimpled.So I imagine it's a factory item but I didn't see a # or oval on it.
Old Feb 10, 2008 | 09:40 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I would venture to guess it has been repainted by the sanding scratch marks (obviously) and by the new rivets.
I would expect an engineering number or a Ford logo of somekind though.
Old Feb 10, 2008 | 01:00 PM
m78's Avatar
m78
My eyes are going bad, I didn't see the sanding marks (mine)until the pic was posted extra large.I'm half tempted to pull it back off and repaint
Getting old sucks
Old Feb 10, 2008 | 04:59 PM
Bullitt390's Avatar
Bullitt390
What I find suprising is how many different odd n ends show up on these trucks. I never knew there was a hood locater thing until that picture was shown. Just like the rear window defrost that was posted earlier.
It's crazy the amount of stuff that is out there for these trucks.
Josh
Old Feb 10, 2008 | 09:20 PM
Jermafenser's Avatar
Jermafenser
That was only used on Broncos and for pickups that came with the factory topper. In addition in that center latch, there are a pair of reinforced hood brackets that are bolted on after the hood hinges. In an event of an accident, the hood hinges will pierce the cowl.
73-79 trucks have a bad rep for popping hoods on their own.
Old Feb 11, 2008 | 01:49 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
never heard of / seen a 73-79 hood pop up by itself. they have a safety catch.
Old Feb 11, 2008 | 01:53 AM
78_f800crewcab4x4
chegies are the ones that have bad rep, (hoods that bend in half)
Old Feb 11, 2008 | 09:14 AM
tude's Avatar
tude
i had a 76 f150....every time my freind would say " man it would suck if the hood popped up at a time like this." that dang thing would pop. the last time it happened we left it on the side of the interstate.......other than that ive had none pop.
Old Feb 11, 2008 | 04:05 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Just saw the same thing on a bronco with 10/77 on door tag, but owner said its a 78, buy it has square head light's ='s 79 right? Pretty cool anyway.
Old Feb 11, 2008 | 04:39 PM
Mil1ion's Avatar
Mil1ion
The parts book doesn't show any reference to this type of hood latch or guide.
Must be a Bronco thing ?
78/79's F-series looked like this.
Old Feb 25, 2008 | 12:06 AM
masterbeavis's Avatar
masterbeavis
I asked a buddy of mine about this, here was his reply.
Originally Posted by my buddy
Yes, 79s only. It was part of the 'keep the fug'n hood where it's sposed to be in a head on collision and not shear off the drivers noggin' package. It also had bars on the hood hinges that drove into the firewall on impact and kept the hood in place, otherwise it could raise up 6" and shear off the cab above the dash.
It coresponds with Jermafensers response.
Old Feb 25, 2008 | 03:46 PM
RCrawler's Avatar
RCrawler
Is it true that the bracket is only found on Broncos and trucks that came with toppers? Why would that make a difference?
I hit a concrete abutment at 35 mph, just outside of the LH framerail. The hood was about 2" higher at the cowl (which was pushed in ALOT), but it was still latched. I could imagine that if the hood did come apart from the hinges, it would hit the A pillars and go upward. Not through them.
Jason
Old Feb 25, 2008 | 06:12 PM
fmc400's Avatar
fmc400
MSEE
Jason
I don't understand either. My '79 doesn't have any sort of brackets. I took a hit in it in the RH front corner at maybe 15-20 one time and the hood didn't move.
