no start
Old Feb 9, 2008 | 05:22 PM
hacki's Avatar
hacki
no start
I pulled the truck in to replace front end parts but then it would not start i get code for p2623 inj control pressure regulator can someone help any suggestions?
Old Feb 9, 2008 | 07:21 PM
bismic's Avatar
bismic
The ICP has had pigtail and connector problems. Maybe do some wiggling on these to see if it helps.
What year is your truck?
Old Feb 9, 2008 | 08:10 PM
denman81's Avatar
denman81
Sounds like the ipr (Injector controll pressure regulator) valve went on ya! have fun! They kinda suck because theyre a pain to get to and you need a special wrench to get it on and off. I used a BIG deepwell socket and cut a notch in it for the wire plug to slide in when you slide the socket onto the ipr.
Old Feb 9, 2008 | 08:26 PM
bismic's Avatar
bismic
Keep us informed! Again - what year truck?
edit -
Nevermind - it is a 2004 from your profile.
When asking for help, give these specifics. Don't need to take the time up of those you are getting help from (just a suggestion - you get more posts that way).
Check out the link to the 6.0L Bible below. Looks like Denman is steering you the right direction.
http://dan.prxy.org/Truck/6L_bible_h...l/Page_10.html
Old Feb 10, 2008 | 10:14 AM
hacki's Avatar
hacki
thaks for the help
natew
Nov 16, 2015 12:22 PM
Fastbird
Crossovers
Feb 24, 2015 09:51 AM
stan'37
Aug 30, 2013 04:17 PM
ssnbdr75
Oct 13, 2011 06:33 AM
