harpoon mod
Old Feb 9, 2008 | 01:51 PM
robjs111's Avatar
robjs111
harpoon mod
does anybody know about the harpoon mod for 2001 7.3 diesels? thanks.
Old Feb 9, 2008 | 02:16 PM
Pocket's Avatar
Pocket
What do you want to know about it?
Old Feb 9, 2008 | 06:47 PM
robjs111's Avatar
robjs111
curtis, figured it out, harpon mod that is. can u tell me y u upgraded to the Garrett GTP38R Ball Bearing Turbo and what kind of gains did u see? also can u tell me about Terminator Engineering High Pressure Oil System, Deleted Exhaust Backpressure Valve w/non-EBPV Pedistal, Stainless Steel High Pressure Oil Crossover mods??? thanks. rob.
Old Feb 9, 2008 | 09:14 PM
Pocket's Avatar
Pocket
I swapped the turbo because 1) I had major surge issues with the stock turbo and 2) I was planning to add big oil later and the stock turbo wouldn't be enough for what I wanted. Strictly swapping the turbo out didn't net me any performance gains. In fact, I still ran the same ET's in the quarter mile. However, the surge is gone, and I can safely run 30+ psi of boost without killing the turbo.
The Termy is great. It has worked flawlessly, and Joey at TE has excellent customer service. The Terminator allows me to run higher oil pressures, resulting in better fuel atomization and power with less smoke. The Termy alone dropped my drag strip times by 8/10ths of a second.
I removed the EBPV because I didn't use it. Kept it disconnected for over a year before taking it out. The pedistal came out at the same time, also because it was leaking oil everywhere.
That mod connects both of the high pressure oil rails. Helps smooth the idle out a bit. Some trucks benefit more than others. I don't really need it now that I have the Terminator setup, but I kept it on anyway. Doesn't hurt.
Old Feb 10, 2008 | 10:06 AM
robjs111's Avatar
robjs111
chris, do u recommend the high oil pressure system?? benifits of the termy is better performance, mpg?? what is price of kit?? can u tell me more about the exhaust backpressure valve and deleted ebpv?? where is it located, what does it do and what did u gain by removing it?? instead of replacing stock turbo can a banks wicked wheel be used and prevent surge?? thanks. rob.
Old Feb 10, 2008 | 10:30 AM
aklim's Avatar
aklim
I use a BTS dual oil pump. This is the one that sits one on top of the stock unit. I don't know about better mpg since I am always driving it like I stole it. I do know that I was using Big Oil tunes before the BO system went it. It would smoke when I romped on it. Now, it has no smoke virtually. Better atomization. About $2400. With that, the High Pressure Crossover is not needed since it equalizes pressure on both heads.
microdevil45
60
Oct 27, 2021 02:03 PM
rat49f6
29
Sep 26, 2019 04:57 PM
TNT in Round Rock
Feb 17, 2007 11:53 PM
BillWoeb
Jan 22, 2006 02:35 PM
Jerrod
Mar 28, 2004 07:56 AM
