lag on every shift
Old Feb 8, 2008 | 08:59 PM
ozzy460's Avatar
ozzy460
lag on every shift
what do i need to do to cure this, 94 5 speed 3/4 4x4, take off and it pulls hard but has a lag till the rpms get up, does this on every shift, is this normal, its annoying
c00nhunterjoe's Avatar
c00nhunterjoe
exhaust, intake, chip
Old Feb 8, 2008 | 09:03 PM
farmer ford's Avatar
farmer ford
beautiful recipe!!
Old Feb 8, 2008 | 09:04 PM
ozzy460's Avatar
ozzy460
got exhaust, 3 1/2 down pipe no cat no muffler twin 5 in stacks, was thinking intake, is it better to buy or build? and i just bought a programmer, would that work the same as a chip? how big a chip?
Old Feb 8, 2008 | 09:13 PM
gt8684's Avatar
gt8684
have you check that little screen to the right fuel filter... could be clogged up?
Old Feb 9, 2008 | 07:13 AM
bkcowboss's Avatar
bkcowboss
also check all your hose clamps after the turbo, mine ha loosened up with age causing loss of boost
Old Feb 9, 2008 | 08:28 AM
westtntrucker's Avatar
westtntrucker
With a 5 speed (apposed to an automatic), you will get some turbo lag. An auto will shift faster than a stick. this will allow the turbo to unspool, then when you release the clutch and get back into the throttle, you will have to wait for the turbo to spool up again to start producing boost which equals power.
Try shifting faster and see if it performs better. If not, (as mentioned above) start with a new fuel filter (clean the FPR screen while your in there), check boot clamps, etc.....
Old Feb 9, 2008 | 09:01 AM
ozzy460's Avatar
ozzy460
ok will try it, and check everything
Old Feb 9, 2008 | 07:01 PM
c00nhunterjoe
build your own air intake, if you need pics 50+ people will post them...lol
Old Feb 9, 2008 | 08:04 PM
ozzy460's Avatar
ozzy460
i work in a machine shop so i'll build one
slipray74
Feb 17, 2014 11:07 PM
swmr1
May 23, 2013 06:07 PM
Hostilact89
Modular V8 (4.6L, 5.4L)
Apr 13, 2012 12:46 PM
HogTied
2004 - 2008 F150
19
Jan 2, 2009 12:04 PM
Guy
1983 - 2012 Ranger & B-Series
Apr 26, 2004 09:45 PM
