Sponsored by: Kumho
Rear shock problem
Old Feb 8, 2008 | 12:43 PM
Erk469's Avatar
Erk469
Rear shock problem
I can't remove the nut on my rear shock, it's stuck..any ideas..I need some help?
Old Feb 8, 2008 | 05:22 PM
385seriesHemi's Avatar
385seriesHemi
If you can get to the shock "arm" or shaft with a vice grip, hold it with that and remove the nut. That is if you are talking about the one at the top.
Old Feb 8, 2008 | 05:41 PM
racincowboy's Avatar
racincowboy
Try using some PB blaster on it that will usually take care of it. Or try tightening it very slightly. I would imagine that you have grime or rust built up in the threads.
Old Feb 9, 2008 | 04:23 PM
blue beast's Avatar
blue beast
propane persuasion never hurt anybody just mind the fuel line!!
Old Feb 10, 2008 | 01:41 AM
Sycostang67's Avatar
Sycostang67
If you have room, a grinder or a sawzall can work too. I had to use a grinder to remove the front struts from my Capri once. Thankfully installing the new ones was a lot easier.
brentkhack
Feb 6, 2017 08:23 PM
pwjackson42
Apr 26, 2016 05:25 AM
jeff8362000
Nov 19, 2009 12:44 AM
jim0517
Mar 23, 2006 10:37 AM
lovethetruth
Aerostar
Jan 21, 2004 08:59 PM
