what do u guys think??
AWS Claim Key: 6688012 Trx Code: 05S34 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:584168A
Cust Comments: FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR.
Tech Comments: INSPECTED HARNESS FOUND BAD CHAFE COPPER SHOWING ON WIRE REPLACED COMPLETE HARNESS. REPLACED CONNECTOR TO IPC SENSOR CAMAPIGN COMPLETED
1FTSW31P34EB20047 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 28-OCT-2003 29-JUL-2004 172450 USA 14 * * * * * * * 18277
AWS Claim Key: 6688013 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 07749 - * Name: FUTURE FORD Ph: 916-7863673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:584168C
Cust Comments: EXHAUST PRESSURE SENSOR REPLACEMENT AND RECALIBRATION
Tech Comments: REPLACED EP SENSOR AND CONNECTOR RECALIBRATED PCM TCM AND FICM
AWS Claim Key: 6688014 Trx Code: 59B01 Labor Hrs: 0.3
Cust Comments: ONE TIME CUSTOMER ASSURANCE TEST DRIVE.
Tech Comments: ROAD TEST TRUCK 12 MILES PERFORMANCE NORMAL
1FTSW31P34EB20047 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 28-OCT-2003 29-JUL-2004 172450 USA 18 2H02 030008 5C3Z 6F089 A E29 41 22501
AWS Claim Key: 8142977 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 05445 - * Name: MEL CLAYTON FORD Ph: 805-6822444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-2005 Doc #:06641051
Cust Comments: CHECK ENGINE LIGHT ON DRIVING, STARTED TO RUN ROUGH AT TIMES WHILE DRIVING PER CUSTOMER
Tech Comments: X ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTSW31P34EB20047 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 28-OCT-2003 29-JUL-2004 172450 USA 19 2G02 030008 4C3Z 12A690 BA L65 D1 23550
AWS Claim Key: 8631773 Trx Code: S07 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 07900 - * Name: FORD OF DUBLIN Ph: 925-8295211 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:03587551
Cust Comments: CUST STATES FLUID LEAKAGE FROM REAR OF ENGINE AREA
Tech Comments: GLOW PLUG HARNESS VERIFY CONCERN,TRACED TO GLOW PLUG HARNESS LEAKING OIL
1FTSW31P34EB20047 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 28-OCT-2003 29-JUL-2004 172450 USA 27 2H02 030008 * 6F089 * E29 42 38542
AWS Claim Key: 10596212 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 07891 - * Name: FRONTIER FORD Ph: 408-2411800 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2006 Doc #:00109551
Cust Comments: CUST STATES CHECK ENGINE LIGHT IS ON
Tech Comments: WPI PERFORM DIESEL DIAG, CLEAN VALVE, TEST, R&R TURBO, RD TEST, OK
i would highly recomend one, IF you get a good one like mine, even when the motor was bone stock BONE STOCK, i put an SCT and cranked over 400HP on stock head bolts with just an exhaust/intake gauges... not even a puke issue at the degas bottle..
however, my ONE complaint is the dash.. the -04 just reminds me of a work truck. same dash as my old dump truck ya know.. the 05up interior is MUCH nicer and the dash/gauges are much nicer to look at..
i've been considering whether or not the -05 up dash would bolt into my interior, because i've spent way too much time/money on this truck to get rid of it, and if i'm stuck with my old dash, then so be it, it's worth the sacrifice to have the beast that i do.. ! ! !
Mark
What Job # did you get? (I guess that's off topic for the 6.0 forum...)
