Head Gasket 2003 OASIS
Old Feb 8, 2008 | 06:46 AM
sundy58's Avatar
sundy58
Head gasket was replaced in April 2007. Bold text below.
So do I run the other direction as fast as possible? Or call the dealer and find out how the repair was done? It's a pretty truck, Lariat, but...
How much is a rebuilt engine? Installed.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC
CD DIST(Miles)
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 7 2G04 031401 * 12A650 * D42 42 11886
AWS Claim Key: 5226065 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 07199 - * Name: TEAM FORD Ph: 712-2778420 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2004 Doc #:205708A
Cust Comments: CUSTOMER STATES THE TRUCK IS LACKING POWER AND IS GETTING POR FUEL ECONOMY.CK ENGINE LIGHT ON ONCE.CHECK AND ADVISE.
Tech Comments: ROAD TEST,RUN ENGINE PERFORMANCE TESTS P0404,P2263,CK BOOST 28LBS,REPROGRAMMED MODULES,ROAD TEST
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 9 2H01 030008 3C3Z 6K682 AARM N11 14 13478
AWS Claim Key: 6034201 Trx Code: S07 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 07199 - * Name: TEAM FORD Ph: 712-2778420 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2004 Doc #:207988A
Cust Comments: CUSTOMER STATES THE TURBO MAKES A BEARING NOISE .CHECK AND ADVISE
Tech Comments: CK FOR NOISE,CALLED HOTLINE,R&I AFTERMARKET AIR CLLEANER ASSEMBLY,REPLACED TURBO ASSEMBLY,ALSO REPAIRED CONCERN FOR LINE B
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 9 1H03 030008 3C3Z 9F452 AC D13 42 13478
AWS Claim Key: 6034202 Trx Code: E84 Labor Hrs: 7.6
Dlr Cd-Sub Cd: 07199 - * Name: TEAM FORD Ph: 712-2778420 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2004 Doc #:207988B
Cust Comments: CUSTOMER STATES THE ENGINE IS RUNNING ROUGH STATES IT RECIEVED A EGR CODE.CHECK AND ADVISE
Tech Comments: RUN ENGINE PERFORMANCE TESTS P0404,P2263,P0238,CLEARED CODES,ROAD TEST AND MONITOR PIDS,TEST EBP SENSOR,REPLACED VGT CONTROL VALVE PER SERVICE MESSAGE,ROAD TEST,MONTOR MGP PIDS,MONITOR EGR PIDS,REPLACED EGR VALVE,ROAD TEST
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 15 2H01 030008 3C3Z 6K682 AARM D36 41 22956
AWS Claim Key: 8447667 Trx Code: E91 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 03292 - * Name: SIOUX CITY FORD LINCOLN MERCURY Ph: 712-2778420 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2004 Doc #:224182A
Cust Comments: CUSTOMER STATES THE TRUCK LACKS POWER AND HAS TO PUT PEDAL ALL THE WAY TO THE FLOOR AND HAS NO POWER.CHECK AND ADVISE
Tech Comments: ROAD TEST,RUN ENGINE PERFORMANCE TESTS ALL PASS CODES,MONITOR PIDS,CALLED HOTLINE,REPLACED VGT,ROAD TEST,CONCERN STILL PRESENT,CALLED HOTLINE,R&I AFTERMARKET AIR CLEANER ASSEMBLY,REPLACED TURBO CHARGER,ROAD TEST,MONITOR BOOST,RETEST EEC OK
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 15 2A01 031201 4C3Z 9N622 AA G29 42 22956
AWS Claim Key: 8447668 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03292 - * Name: SIOUX CITY FORD LINCOLN MERCURY Ph: 712-2778420 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2004 Doc #:224182B
Cust Comments: AIR FLOW LIGHT IN THE DASH IS ON.CHECK AND ADVISE
Tech Comments: REPLACED AIR FLOW INDICATOR
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 20 6P07 01XXXX 2C3Z 7811586 BAB N30 01 30977
AWS Claim Key: 10148385 Trx Code: E84 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 00774 - * Name: SHOTTENKIRK FORD-MERCURY Ph: 319-3852261 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:24-MAR-2005 Doc #:141378A
Cust Comments: CUSTOMER STATES THAT THE UPPER SUNGLASS STORAGE WILL NOT SHUT COMPLETELY
Tech Comments: REMOVED OVERHEAD CONSOLE AND COMPARTMENT ASSEMBLY REPLACED GLASSES STORAGE DOOR
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 42 * * * * * * * 86254
AWS Claim Key: 14780575 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00110 - * Name: KEAST FORD LINCOLN MERCURY, INC. Ph: 712-7552116 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:0485451
Cust Comments: CAMPAIGN 59B01 CUSTOMER TEST DRIVE.
Tech Comments: PERFORMED RECALL 59B01
AWS Claim Key: 14780576 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00110 - * Name: KEAST FORD LINCOLN MERCURY, INC. Ph: 712-7552116 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:0485452
Cust Comments: CAMPAIGN 06E17 CONTROL MODULE RECALIBRATION.
Tech Comments: PERFORMED RECALL 06E17
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 45 2E06 030008 3C3Z 9F838 EA L65 42 94941
AWS Claim Key: 15060859 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 00110 - * Name: KEAST FORD LINCOLN MERCURY, INC. Ph: 712-7552116 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2007 Doc #:0498711
Cust Comments: CHECK FOR ENGINE OIL LEAK.
Tech Comments: REPLACED ICP SENSOR BECAUSE IT WAS LEAKING OIL. REPLACED WIRING HARNESS ON IT ALSO IT WAS SOAKED WITH OIL. MT TIME TO REPLACE WIRE HARNESS
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 45 1A02 030102 * 6051 * L87 D8 95583
AWS Claim Key: 15130721 Trx Code: E72 Labor Hrs: 16.4
Dlr Cd-Sub Cd: 00110 - * Name: KEAST FORD LINCOLN MERCURY, INC. Ph: 712-7552116 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2007 Doc #:0500481
Cust Comments: BLOWS OUT WHITE SMOKE WHEN FIRST START AND SMELLS ANTIFREEZE.
Tech Comments: PRESSURIZED COOLING SYSTEM AND FOUND HEAD GASKET LEAKING AND EGR COOLER DEVAC A/C REMOVED HEATER BOX. REPLACED TURBO Y PIPE LEAKIGN EXHAUST. RPLACED EGR COOLER. REPLACED HEAD GASKETS. REPLACED HEATER HOSE TUBE ON FRONT COVER BECAUSE STUCK IN COVER AND BROKEN OFF REPLACED DIPSTICK TUBE STUCK IN BLOCK. REPLACED EXHAUST MANIFOLD GASKETS. REASSEMBLED AND RETEST O.K. ROAD TEST O.K. RECHARGED A/C CHANGE
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 46 6Y20 000001 * MISC * A98 82 96030
AWS Claim Key: 15147627 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 00110 - * Name: KEAST FORD LINCOLN MERCURY, INC. Ph: 712-7552116 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAY-2007 Doc #:0502251
Cust Comments: CUSTOMER REFUND
Tech Comments: CUSTOMER REFUND $100.00 FOR DIESEL DEDUCTABLE
1FTNW21P73ED12237 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 24-APR-2003 23-AUG-2003 158518 USA 48 1H03 030008 4C3Z 9F452 A D42 42 99424
AWS Claim Key: 15350620 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03480 - * Name: WYMAN'S FORD, INC. Ph: 712-7782126 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:03-JUL-2007 Doc #:01251201
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON
Tech Comments: SCAN TEST P0238 P0401 P0404 DIAGNOSE AND REPLACE EGR VALVE LABOR OPS 6005F .4 6005F1 .1 6005F1X1 .1 6005F12 .4 6005F39 .4 HRS CC42 CCCD42 CASUAL PART # 9J460 $ 100.00 DEDUCTIBLE
Old Feb 8, 2008 | 11:59 AM
rbloodhound's Avatar
rbloodhound
I think that I would run. It looks like 2 turbos and did indicate aftermarket air filter. Thats probably what took out the turbo. I am pretty sure the truck has been run with some kind of tuning device. It could get really expensive if you have to pay out of your pocket for something.
Old Feb 8, 2008 | 09:30 PM
brickie's Avatar
brickie
Run!.........
Old Feb 8, 2008 | 09:36 PM
sundy58's Avatar
sundy58
Short and sweet!
That was my instinct and run it is!
Old Feb 10, 2008 | 02:49 PM
MIKE1646's Avatar
MIKE1646
Yes run as fast as you can!
Old Feb 10, 2008 | 08:03 PM
Bulldog66's Avatar
Bulldog66
wholly Oasis report Batman!
Run, don't walk.
Seriously.
Run.
mushman
Dec 21, 2010 04:46 PM
Firemudder
Apr 20, 2009 03:56 PM
gopedoligist
Feb 20, 2008 12:10 PM
95Z71
Oct 28, 2007 01:26 PM
77hiboyboy
Oct 2, 2006 02:38 AM
