leveling kit
Old Feb 7, 2008 | 07:45 PM
r-rat's Avatar
r-rat
leveling kit
Installed 2.5" leveling kit on my 05 s-crew,when you turn wheels all the way the front on the truck drops. Any ideas on this?
Old Feb 7, 2008 | 09:21 PM
SUPERDUTY_untouchabl's Avatar
Are you trying to say that when you cut the wheels in one direction all the way the front end drops? Did you get it aligned?
Old Feb 8, 2008 | 06:37 PM
r-rat's Avatar
r-rat
leveling kit
No not yet, just put the kit on. Will that fix the problem?
Old Feb 8, 2008 | 07:14 PM
DaMole's Avatar
DaMole
You definitely need to get the truck aligned. It could be the problem. That is the first thing you need to do though.
Old Feb 18, 2008 | 06:26 PM
r-rat's Avatar
r-rat
leveling kit
I just got my truck back from getting a alignment tonight, the front still drops when you turn the wheels to lock. Any other ideas?
Old Feb 18, 2008 | 09:40 PM
dfishrmn88's Avatar
dfishrmn88
I just installed a 2" on mine and it does the same thing. I'm not sure if it always did this and am just noticing it. I did see that there are a "tab" and a "V" that are on the lower arm that match up when turned to full lock. This may be causing it.
Old Feb 18, 2008 | 09:43 PM
wreedZ71's Avatar
wreedZ71
What are you saying the truck sits lower when the wheels are at full lock?
Old Feb 18, 2008 | 09:48 PM
burner879's Avatar
burner879
Ive noticed that with mine. Ive got a 2.5 inch lift and I had it installed by someone I trust so I would assume they would not forget to align it.When I pull into a parking space and I go to straighten the wheel the front end kinda hops up but I dont notice the front end dipping. Kind of the same problem I guess but it is not something I worry about. If I do find out that it is a serious problem I will have it fixed though.
Old Feb 18, 2008 | 09:49 PM
wreedZ71's Avatar
wreedZ71
it is proablly the design of the suspension. it proablly does it even without the leveling kit.
Old Feb 18, 2008 | 09:53 PM
dfishrmn88's Avatar
dfishrmn88
I argee with wreed. I think I just noticed it after I installed the kit. There were wear marks on the "tabs" I mentioned that I noticed during the install process.
Old Feb 18, 2008 | 09:55 PM
wreedZ71's Avatar
wreedZ71
what tabs are you refering to?
Old Feb 18, 2008 | 10:03 PM
dfishrmn88's Avatar
dfishrmn88
I wish I could desrcribe them better. There is a small bit of pointed metal on the lower control arm and V that matches with that at full lock.
Old Feb 18, 2008 | 10:05 PM
projump's Avatar
projump
I don't think it's a problem. As you turn the wheels they will lean over several degrees ( called camber )
therefore causing the front to lower.
Old Feb 18, 2008 | 10:12 PM
dfishrmn88's Avatar
dfishrmn88
I just went out to look at them. They are on each side of the lower ball joints and behind the brake disc. I believe they are meant be be "stops" so the wheel isn't turned too far. Anyway, one is a "V" which I think centers the wheel when turned full lock and may cause the movement.
maxnoodle
Mar 17, 2008 12:02 PM
machanic
Jun 10, 2007 01:27 PM
abendx
Aug 16, 2002 08:21 PM
TexasGuy001
Jan 22, 2002 03:44 PM
visegrip
Offroad & 4x4
Dec 23, 2000 12:49 PM
