I just installed a 2" on mine and it does the same thing. I'm not sure if it always did this and am just noticing it. I did see that there are a "tab" and a "V" that are on the lower arm that match up when turned to full lock. This may be causing it.
Ive noticed that with mine. Ive got a 2.5 inch lift and I had it installed by someone I trust so I would assume they would not forget to align it.When I pull into a parking space and I go to straighten the wheel the front end kinda hops up but I dont notice the front end dipping. Kind of the same problem I guess but it is not something I worry about. If I do find out that it is a serious problem I will have it fixed though.
I argee with wreed. I think I just noticed it after I installed the kit. There were wear marks on the "tabs" I mentioned that I noticed during the install process.
I just went out to look at them. They are on each side of the lower ball joints and behind the brake disc. I believe they are meant be be "stops" so the wheel isn't turned too far. Anyway, one is a "V" which I think centers the wheel when turned full lock and may cause the movement.
