4x4 HUB question
Old Feb 8, 2008 | 06:50 AM
  #31
SIZMDRS's Avatar
SIZMDRS
Originally Posted by X_Hemi_Guy
I MAY have JINXED myself...
This morning my development streets were pretty icy...so I engage 4 wheel...no problem...a few seconds and light comes on dash...I can tell all is locked up with the front wheels pulling.
I get to the main drag and disengage 4 wheel...I start to hear this low pitch whine...I'm thinking the radio...so I turn that off...but it is still there.
I'm going maybe 30mph so I re-engage 4 wheel but the indicator pops on IMMEDIATELY...
I dis-engage 4 wheel and continue to hear it. I come to a light and start to slow...the whine pitch is speed dependent...
I couldn't back up as there was traffic behind ... but I'm probably used to my old '92 Exploder I had where you had to back up to 'unlock' the auto hubs...
By the time I got to work (2.5 more miles)...the noise had completely stopped...
It is obviously 4 wheel related...
Any thoughts?...
joe.
I had the same thing happen when I went to NJ, I was told to put it in Neutral. until you hear, feel the release.
Good Morning!!
Beth
Old Feb 8, 2008 | 07:41 AM
  #32
afreemanmd's Avatar
afreemanmd
Good Morning!!
Beth
you only need to go into neutral when shifting in and out of 4 wheel low. 2wd to 4hi is (supposed to be lol) on the fly shift while driving.
Joe,
if the whining has stopped, the hubs probably finally unlocked, but just to be sure, you can try to spin the stub shafts at the knuckles, and that'll tell you for sure
Old Feb 8, 2008 | 09:50 AM
  #33
mudmaker's Avatar
mudmaker
the hubs don't unlock until you stop, sometimes you have to back up.
Old Feb 8, 2008 | 10:48 AM
  #34
X_Hemi_Guy's Avatar
X_Hemi_Guy
Thanks guys...I 'normally' do back up...just habit from the Exploder hubs...I just feel better doing it I guess...I was able to back up when I got to work...so I'm hoping all is well...
Thanks again!
Old Feb 11, 2008 | 07:48 PM
  #35
aortizexcursion's Avatar
aortizexcursion
Were we ever going to try to get how the 4wheeldrive system works into the Tech Folder?
Old Feb 28, 2008 | 04:11 PM
  #36
Pocketrocketz1's Avatar
Pocketrocketz1
I have a 2000 Ex and my hub switches won't turn and the lettering/graphicsthat tell me if they are in auto or locked is warn off, so I don't know what possition it's in right now. I mean, they will not turn. i tried to persuase with some channel locks, but I didn't want to break them.
From in the cab, i put my Ex in 4x4 high (it's electronic). It says it's in 4wheel, but only my rear wheels spin. If I give it gas and the rears slip too much, I feel a slam, for an instant, it feels as though the fronts wheels are engaging and then disengaging.....sort of like my full time AWD Explorer use to do in 4X4 auto did.
Do I need to pull my hubs apart and where is the best place to get a service manual so I can see what i need to do to get the job done? Could these hubs be stuck in locked mode. I'm guessing my 4 wheel should work, since they are either auto or locked....could my problem be my hubs and something else?
Old Feb 28, 2008 | 06:16 PM
  #37
X_Hemi_Guy's Avatar
X_Hemi_Guy
I believe this link is contained somewhere above...but it gives GREAT instructions on taking apart and cleaning and reassembly of the hubs...
http://guzzle.rbmicro.com/allube.html
The hubs are vacuum controlled...perhaps your vac lines need replaced?...don't know...
GOOD LUCK!
joe.
7622RM
1983 - 2012 Ranger & B-Series
18
Mar 22, 2019 10:25 PM
Bowie Goatman
Jul 17, 2016 07:48 PM
FoxClubNiner
Jun 23, 2016 08:10 AM
Ruffasacob
16
Dec 18, 2015 03:37 PM
pumper3
Apr 14, 2012 11:26 AM
