Vibration at Low speed
Old Feb 6, 2008 | 10:11 PM
guitarpicr's Avatar
guitarpicr
Hey guys - I recently installed 2" front spacer lift and air ride bags in the rear. I'm running about 60 psi in the rear bags and truck is pretty close to level. Now I am getting a fairly heavy vibration on low speed start up. Once Im moving(over 15-20 mph) it runs fine. Any thoughts on what to check? Thanks,
Old Feb 6, 2008 | 10:15 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Probably because you aired up the bags, lowering the axle from the chassis, changing driveshaft angle. Did you do this just to compensate for the lift in the front? If so, try removing the air pressure in the bags (keep about 5psi in them at all times however), and see if the problem goes away. If so, you will need to add a small shim (1/4" or so) to the driveshaft carrier bearing to decrease the angle.
Old Feb 6, 2008 | 10:31 PM
guitarpicr's Avatar
guitarpicr
Ill try letting out some air Kris -I installed the bags for towing to keep rear end from sagging. Did the fronts just to keep it from nose diving. The bags do a great job towing, much more stable. Should I just add the spacer cause I like the way it rides with 50-60 psi in the bags even when not towing? Thanks
Old Feb 7, 2008 | 02:12 PM
guitarpicr's Avatar
guitarpicr
If I shim the carrier bearing can I just use some heavy washers stacked up at least to try and see if this takes vibration out? Never done this b4. Thanks, Bill
Old Feb 7, 2008 | 04:24 PM
rebelchevy02's Avatar
rebelchevy02
Do the extended cab, short bed, 2wds have a carrier bearing? The 4wds dont. Not sure about 2wds though.
Old Feb 7, 2008 | 04:50 PM
PowerstrokeJunkie
The regular cabs and super cab shortbeds don't have any, but anything longer does.
Old Feb 7, 2008 | 05:32 PM
guitarpicr's Avatar
guitarpicr
Kris -Im gonna make my own shim out of 1/4" stock -Just wanted to try it w/ washers first to make sure the thickness is right. I dropped the pressure to 10 psi and like you said no more vibrato. Is there a ratio for amount of lift to amount of shim? Thanks, again
Old Feb 7, 2008 | 06:23 PM
rebelchevy02
Originally Posted by guitarpicr's sig
02 -F250 Lariet 7.3 PSD- SB -X Cab 2 wd
This is why I ask......... ECSB, according to your sig.
Old Feb 7, 2008 | 07:36 PM
guitarpicr's Avatar
guitarpicr
Mike - Not sure myself -Any body have a pic of the carrier bearing ?I thought it was the mid way (looks kinda like a pillow block bearing) has a bolt on either side.
Old Feb 7, 2008 | 08:12 PM
rebelchevy02
Yea it is, have you crawled under your truck to verify you have one?
Old Feb 7, 2008 | 09:49 PM
guitarpicr's Avatar
guitarpicr
Yes Mike - I went out and double checked it -Just like in the pic. Thanks, Bill
Old Feb 7, 2008 | 09:52 PM
PowerstrokeJunkie
I believe, the formula is 1/4" for every inch of lift. I know i lifted the rear of my truck 4-5" and it needed just over an inch of shimmage.
Old Feb 7, 2008 | 10:00 PM
guitarpicr's Avatar
guitarpicr
Thanks Kris and Mike for the help.
Old Feb 7, 2008 | 10:35 PM
rebelchevy02
Good deal, I was unaware the ecsb config in 2wd had a two piece driveshaft.
NBC-Steve
16
Jun 26, 2011 06:11 PM
gixer311
2004 - 2008 F150
Sep 2, 2010 08:55 PM
Blue Rebel
Feb 23, 2010 07:55 PM
FORDNAV
1997 - 2003 F150
Dec 24, 2002 09:02 AM
souts
1983 - 2012 Ranger & B-Series
Jan 12, 2002 09:14 AM
