Sensor on tranfer case???
Old Feb 6, 2008 | 10:26 AM
Big_Man_Brad's Avatar
Big_Man_Brad
I have an e40d trans..I herd that the sensor on the transfer case has somthing to do with my cruise so i unplugged it and a bunch of debrie came out of it.I was wondering what i should clean it with like carb cleaner and also if i can unscrew that sensor in the transfer case to clean it..And if thats what they mean by cleaning it.And will any fluid run out when i take the sensor out...
Thanks Brad
Old Feb 7, 2008 | 09:01 AM
jr32560's Avatar
jr32560
uh electric connection ?? use contact cleaner,-the use dielectric grease and plug r in-don't think ya got to remove it to clean it-sensor on transfer case has to do with cruise control??what year is it???
Old Feb 7, 2008 | 01:04 PM
Surge08's Avatar
Surge08
I thought the sensor was on the rear diff.
Old Feb 7, 2008 | 02:08 PM
quicklook2's Avatar
quicklook2
do not use carb cleaner.
Old Feb 7, 2008 | 02:10 PM
superduty4x4's Avatar
superduty4x4
The sensor that controls the cruise is in the rear diff, not the T-case. Not sure what you pulled out, but I'd just wipe it off and stuff it back in there.
Old Feb 7, 2008 | 02:18 PM
Big_Man_Brad
1996 f-250 f-250 its in my sig...ok i did so...
Old Feb 7, 2008 | 06:37 PM
jr32560's Avatar
jr32560
yeah my thought too quicklook2-it may melt the plastic-I was going to say brake cleaner?? but then I am not sure-figured contact cleaner was a safe bet!!!--and yeah the vss is on the rear?? don't know what the sensor is he is referring to-haven't found one on mine yet-well mine is older-maybe a push button transfer case-may be his solenoid for the electric transfer case???mine has no wires!!!
Old Feb 7, 2008 | 06:53 PM
brown 4x4's Avatar
brown 4x4
In 1996 the VSS in the rear is for ABS, cruise, and the PCM. I don't think my 95 has a sensor on the transfer case...my other 95 does but it's for push button 4x4, which F-250's don't have. Are you sure it's not on the tailhousing of the transmission?
Careful with brake clean too. Some isn't safe for all plastics. Some will say wether they're safe or not.
Old Feb 7, 2008 | 08:05 PM
Big_Man_Brad
I'm sure there is a sensor on the tranfercase..I just cleaned it off and put it back on so i have no problems..I just have to hunt down this cruise control problem..It really bothers me...
Old Feb 7, 2008 | 08:51 PM
brown 4x4's Avatar
brown 4x4
Could it be the switch for the 4x4 and low range lights?
Old Feb 7, 2008 | 08:57 PM
JRCF's Avatar
JRCF
the VSS in the rear end controls the cruise, and the ABS, I did not know that. So if the cruise is working the ABS should be working right?
powerstroke72
6.7L Power Stroke Diesel
9549
Feb 8, 2023 05:07 PM
C. Lee Colbert
1983 - 2012 Ranger & B-Series
Oct 3, 2014 09:16 AM
Tylus
Jan 6, 2014 09:15 AM
78 & 87 Super Cab
15
Sep 4, 2013 10:27 AM
Fordalways69
Sep 1, 2013 01:35 PM
