Heated Mirror ???
Old Feb 4, 2008 | 09:08 AM
BigFord74's Avatar
BigFord74
Heated Mirror ???
I did a search but couldn't find anything. I thought someone had, had problems with there's before. If so, can someone post a link plz. If not here's my ?
Is there a way to check to make sure they are working?
We had a small snow fall Thursday and snow/little ice collected on my driver's mirror to the point of not being able to see. We got it parked and neither mirror felt warm at all. I check/pulled the fuse. After reinstalling it. They seem'd to work fine. CLear'd right up.
Today we have a ton of humidity and lot's of moisture on both driver's/passenger mirrors. I had to drive into town to get our dog from the vet's. No less then a 8mile 1way drive. Got home after picking the dog up/kids dropped off at school. Still have a ton of water build up on the mirrors. Usually the heat helps clear them. Nor did either one feel warm to the touch.
I'm still underwarranty but i'd rather see if there's something silly i can do, kinda like my rear windshield washer problem that got fixed.
Old Feb 5, 2008 | 08:41 PM
BigFord74's Avatar
BigFord74
Can you all with heated mirror's at least do me a favor and confirm that they should be warm to the touch while the vehicle is on?
Old Feb 5, 2008 | 11:17 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Both mirrors are heated
automatically to remove ice, mist
and fog when the rear window
defrost is activated.
they're not warm,at least mine aren't.
Old Feb 6, 2008 | 01:32 AM
CommercialNuke's Avatar
CommercialNuke
You do realize that the mirror heaters are off the same switch as the rear window defroster, don't you. When you turn on the rear glass defroster, the mirrors come on also. At least that's the way my '05 Limited works.
Old Feb 6, 2008 | 06:28 AM
fordtruckster's Avatar
fordtruckster
Smile
when the mirrors are on, they still are not warm to the touch, but I have noticed over time that once turned on, it takes less then 3 or 4 minutes for them to clear off any snow or fog
good luck
Old Feb 6, 2008 | 07:50 AM
BigFord74's Avatar
BigFord74
Hmmm according to the book they should alway's be on.
Went outside cause it sleeted last night, started the truck flipped the backglass switch and walaw mirror's melted.
Wonder who prints that manuals for ford. I'm guessing monkey's.
Thnx for the info. Like my first post. I figured it was something as easy as a switch.
And that's why i come to this site before even talkin to any Stealer's...
Old Feb 6, 2008 | 08:25 AM
mohrds's Avatar
mohrds
Now that the mirror issue is resolved, the really important question from a fellow dog owner...
Is the dog OK?
Doug
Old Feb 9, 2008 | 07:27 PM
BigFord74's Avatar
BigFord74
Ya our Vet kennels our dog when we go outta town. Figure what better place then the vet that see's him when he's sick anyway's.
Old Feb 10, 2008 | 03:27 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
For all those that say here is what the manual in my '05 page 67 states...
"Heated outside mirrors (if equipped)
The main mirror glass is heated automatically to remove ice, mist and fog and activates when the vehicle is started.
Note: The mirrors may be hot to the touch but will not burn. This is a
normal condition.
Type A
The mirror heating elements aredesigned to operate regardless of
the geographic location of the
vehicle. There is no switch to turn
on, or other operator involvement
required other than to start the
vehicle."
Glad you figured it out...apparently reading the F'ing manual didn't help you this time...
Our other vehicle has heated mirrors that are tied to the rear defrost...the Ex manual led ME to believe they were ON all the time...and NO OPERATOR INVOLVEMENT REQUIRED! Apparently the F-ing manual is WRONG?
Joe.
Old Feb 10, 2008 | 04:53 PM
BigFord74's Avatar
BigFord74
Ya, now you see why i asked the ?. It seem'd mine were broke. Cause i took it as if they were on when the truck was on.
acecase
Apr 7, 2019 08:56 PM
fivonut
Jan 25, 2018 03:08 PM
Y2KW57
17
Mar 10, 2016 08:59 AM
fp_5
2004 - 2008 F150
Mar 2, 2015 04:42 PM
the Goat
Sep 15, 2009 01:18 PM
