1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Backup cam in 3rd brake light with dual monitor rearview mirror
Old 01-23-2017, 08:53 PM
acecase's Avatar
acecase
acecase is offline
First of all, hi! I am a new member, but not at all new to forums.
I tow a lot of different gooseneck trailers and I hate getting in and out to look at the ball. After a lot of looking and finding nothing that I liked, I decided that I had to come up with something. I really wanted a centered camera, which meant 3rd brake light. I did find one, for $400. I figured I could do a little better and have some fun.
I went to that big auction site that starts with a lowercase e, and started looking for cameras. The only ones I could find that were surface mount are meant to be installed upside down under a bumper. I did notice that there were four screws on the back. At a cost of $10 I figured I blow that each week, so why not? I bought one from China and took it apart and the cam is held in place by two spots of hot glue. I popped those off and rotated the camera 180° and hot glued it back in and rtv'd it.
Next I needed a 3rd brake light with enough room to mount the camera. I found a led job for $25. When I got it, the led"s are held in place by two screws. I removed those and the light bar came off. I cut a hole in the bottom to route the wire and to be able tighten the 10mm nut that holds the camera wherever you mount it. A 5/16" hole in the lens and I was able to assemble everything. Some more rtv went around the outside.
The mirror is from rearview safety.com. It has two 4.3" displays. It also supports up to 4 cameras. It also has a reverse trigger so one or two select cameras come on when the truck is in reverse. While driving, you can cycle through the displays. This is particularly important to me as it gives me a quick visible check of chains, coupler, etc.
As for the actual install. Overall, it's not hard, tedious but not hard. The headliner has to come down. That entails a lot. All trim, the back seat, sunroof trim ring, grab handles, lights, and visors. I got picked up power, reverse trigger and the factory camera feed from the factory mirror connection. This had to be carefully cut away from the headliner where it was glued in. I pulled it back to the passengers side windshield. All my connections were made behind the grab handle. This way I can pull off one thing and get to everything. As the mirror supports four inputs, I might add two more cameras.
I found some RCA connectors that use set screw terminals. This made the video connection from the factory camera easy. I wrapped all the cable and connections in foil tape to cut down on interference. My factory camera was not great to begin with, so I expected a little fuzzy image. It worked out better than I thought it would. The China cam has a great image.
The one issue I have is that the factory camera has guide lines, and so does the mirror. So for the bumper hitch, I have two sets of guidelines. No real problem, I can still see the hitch clearly.
And lastly, I mounted a capacitor (not battery) dashcam under the mirror.
My total cost was under $350 for everything.
Old 01-24-2017, 07:38 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
Nice job, looks great, and welcome to the site! I have not seen the dual screen mirrors before, has me thinking........
We don't have any issues with posting links to the various parts, personally I encouraged direct links to products that are working well for other users, it helps other find the exact stuff that has been proven to work!
Old 01-24-2017, 01:39 PM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
where did you run the wiring? very nice OP
Old 01-24-2017, 02:29 PM
acecase's Avatar
acecase
acecase is offline
Not sure what part you are referring to, so here's all of it.
I cut the factory wiring loose from the glue o. The headliner and took it back to the right front pillar (windshield). I cut the factory plug loose there and got the video input from the factory tailgate latch cam. I also picked up the reverse trigger, power and ground.
The brake light cam I routed through the factory routee in the cab frame. This was easy since the headliner was down. That wire again went to the front pillar.
Power in that harness is switched from the key, and since I wanted my dashcam to come on when the key is on, I got power from it there. I have a bench top DC supply and during testing the backup cam, dash cam and mirror, they only pull 1.2amps. I think the factory mirror fuse is 2amps, so no worries there. As a side note the dash cam is a capacitor and not a battery. It is made to come on and off with the key. One less button to push.
All connections are behind that one piece of trim (right side grab handle). This way, if I ever need to access it, it is easy. The mirror supports up to four inputs, so I might add two more cams in the future.
Tonight I will post exactly what I used.
Old 01-24-2017, 03:47 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Received 3,326 Likes on 1,743 Posts
Nice job. Reputation points sent to you. (Justice scale icon in upper right hand of post, for those who don't know). And Welcome to FTE!
I'm subscribing to this thread, and want to know more details, like part numbers for the mirror monitor, the camera that you modified, the 3rd brake light, the capacitor dash cam, all of it... a complete write up!
Also, can you post a pic of the third brake light illuminated, so we can see how it looks with the camera in the way of it?
Once again, nice job!
Old 01-24-2017, 05:01 PM
acecase's Avatar
acecase
acecase is offline
cargo lights in daytime and then brake lights. There are three separate LED lights for the brake, I only covered up the middle. My wife says it is very very visible at night
when she is behind me.
Old 01-24-2017, 05:34 PM
acecase's Avatar
acecase
acecase is offline
Now for part numbers and links:
Mirror: RearView Saftey RVS-718-2SC
https://www.rearviewsafety.com/safet...-displays.html
Dashcam: Spy Tec G1W-CB Black Capacitor Edition Dash Camera| Full HD 1080P H.264 Car DVR
Various sources. I used Ebay, but make sure it is a BlackBox product. There are a lot of counterfeits out there. Though light, the black box feels like it is rigid metal covered in plastic. The counterfeits are all cheap feeling plastic.
Here is the direct link: G1W-CB 1080P HD Car Dash Camera /w Capacitor
Dashcam Hardwire kit: Again, i used ebay
Dash Cam Hard Wire Kit - Mini USB - G1W, A118, Mobius and More
Dashcam mirror mount: Yep, Ebay
Rear View Mirror Mount for G1W, G1W-C, G1WH
Brake light: Guess what? Ebay. I just did a quick search and this is the same unit.
99-11 FORD RANGER / -14 F250 F350 SD LED 3RD BRAKE STOP TAIL LIGHT LAMP BLACK | eBay
Backup Camera: There are tons of these on ebay. And after two orders (my truck and wife's car) I think they are all the same. $10 seems to be the normal cost. I only got the cheap ones, and they seem to be great. Just re-seal them good with RTV and take your time and do it right.
170 Balck Anti Fog IP68 Backup Night Vision Car Vehicle Rear View Parking Camera | eBay
RCA plug: ebay of course. Radio shack might have these. I liked the screw terminals and I wrapped them in foil tape afterwards.
10Pcs Phono Speaker Wire cable to Audio male RCA Connector Adapter Jack Plug LED | eBay
As far as a write up, I will anwser any specific questions. I think I covered it pretty well in the initial post. Attached is the only wiring diagram I needed. It is the mirror plug. I made all my connections for the factory cam from it.(screen shot off my phone, sorry for volume bar)
Old 01-24-2017, 06:17 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Thanks again, acecase. Way to make an entrance, blowing us away with a cool mod and clever execution.
Old 01-25-2017, 04:45 AM
acecase's Avatar
acecase
acecase is offline
Thank you.
Old 01-25-2017, 04:49 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Looks great!!!
Wonder if one can find a small video switch to go between truck camera and one like the you used to display the video in the radio screen.
Old 01-25-2017, 06:02 AM
acecase's Avatar
acecase
acecase is offline
All you would need is a simple"y" splitter. The Ford cams and the aftermarket all use NTSC. It is a simple two wire system that is standard for everything from computer displays, to TV's to security cams. With the small wired in the factory harness and the low power output coming from the cam, I would not split it more than once. Ford is not going to use more expensive copper for a wire larger than it needs to be.
From experience, I can assure you, you can split the signal once with no loss in image quality. Be sure you tape the connections with foil tape to prevent interference and to make sure they stay together.
Old 01-27-2017, 10:35 AM
david.brady's Avatar
david.brady
david.brady is offline
Excellent Write-up
acecase, excellent job thank you for sharing.
Old 01-27-2017, 10:55 AM
acecase's Avatar
acecase
acecase is offline
Thank you! Hope this helps someone.
Old 01-27-2017, 09:03 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
love the install!! been tossing around ideas for a multi-camera setup on my dually, and i like this a lot, especially your mounting location. i haven't read through the whole thread yet, but i will shortly, i wanted to at least post so i subscribe to it in case i need to read it later.
Old 01-28-2017, 04:59 PM
acecase's Avatar
acecase
acecase is offline
Here is a good pic that illustrates why I wanted to do this. I am safely rolling about 5mph on an empty road so I can take a good safe pic, but I can hit one button and visually satisfy myself that everything is good. The larger 4.3" screen over the factory 2" is a great improvement. Hooking up was a much smoother experience.
Quick Reply: Backup cam in 3rd brake light with dual monitor rearview mirror
