Electrical problem
Old Feb 26, 2015 | 11:05 PM
fp_5's Avatar
fp_5
Electrical problem
I usually engage in the '73-79 forum or my local chapter but...I just picked up a 2004 F150 FX4 Supercab, I had a safety inspection done and am working through some of the issues. What I thought would be an easy fix has me scratching my head....
The turn signal indicator on the passenger side mirror is not working(front and rear indicators work). I took the mirror apart and get no voltage to the led array, next I pulled the rubber boot off of the harness in the door jam and probed the wires while with a test light and found one of the wires would blink the test lest light but the colour didn't match the the turn signal array, it matched the heated mirror wire. I probed at the heated mirror connector at the mirror and sure enough it blinks! WTF? Then i notice that the heated mirror indicator light on the center dash is blinking? I push the heated mirror button below the indicator light and ALL turn signals (front and rear) stop.
I searched the forum for mirror turn signal issues and found a thread about corroded wire splice below the fuse panel. I checked and have no splice all look ok so I thought I would post and see if I can get some direction or a schematic.
The symptoms are :
_Passenger side mirror turn signal(right turn) indicator does not work
- front and rear turn signal indicators work
- power seat works
-fuses are good
- drivers side all turn signals work fine
- heated mirror indicator light on the dash blinks with the passenger side turn signal
- pushing the heated mirror button when turn signals are flashing (right turn) results in a solid heated mirror indicator light but all other right turn signal indicator stop blinking (off)
Any help would be appreciated. It seems to me that there must be a short between the two circuits but where?
Thanks
Frank
Old Mar 2, 2015 | 04:42 PM
Oldguy4's Avatar
Oldguy4
I think you are right. The two circuits are crossed. Have you checked the plug for the heated mirror switch? The passenger side mirror turn signal might run through there.
alex454
6.7L Power Stroke Diesel
Jun 8, 2011 06:41 PM
Dakrri
Jun 22, 2009 02:03 PM
