Water pump
Old Feb 3, 2008 | 04:38 PM
Mike in Ohio's Avatar
Mike in Ohio
Water pump
The water pump on my 69 started leaking very badly today on the way home. I think it is the gasket between it and the front housing as near as I can tell. Somebody along the way put a 460 in this truck. I haven't been able to find the casting numbers on this motor yet, (too much rust and crud I think). Are all 460 water pumps the same or did they change them somewhere along the line. Thanks alot, Mike
Old Feb 4, 2008 | 07:24 PM
Project_Roxanne72's Avatar
Project_Roxanne72
From my experience, which isnt much, lol. Usually starts leaking right under the pulley when it starts to fail. Theres a little hole there. See if its leaking out of there first. If it is leaking out of the hole then your waterpump is bad. Next I found an Edelbrock Victor Series water pump made to fit a '70-'92 429/460 BB Ford. Part #350-8866 at www.jegs.com . Im assuming that your engine falls into these dates.
Old Feb 4, 2008 | 07:42 PM
Freightrain's Avatar
Freightrain
I'm not big on the 460, but I'd about bet they are pretty much all the same, other then maybe reverse rotation late model stuff? Pick something back in the 70's and you're probably okay.
Old Feb 4, 2008 | 08:31 PM
Mike in Ohio
Thanks alot , Mike
IDIoit
18
Dec 8, 2016 07:06 AM
DieselCamper
20
Nov 1, 2016 01:38 PM
mikefender
Dec 10, 2010 07:44 PM
austynn2001
Aug 29, 2005 05:58 PM
mike460
Mar 30, 2001 07:23 AM
