Thermocouple, befor or after the turbo?
Oh, I can't remember off the top of my head now...I believe I got it in the 3rd cylinder back from the front on that side. That was about the furthest back I could easily reach to get the drill in there and tap out the hole.
Are you wanting to put it in the Y-collector? That'll be tough to get at.
post or pre are both used to keep from melting the pistons.
on big trucks the manufactures quit installing it pre turbo because they would sometimes break the stinger off hence new turbo if lucky motor damage if not.
now adays the stingers are built better and probably not a problem due to the exhaust on a v8 either.
this is a beat to death argument where the rea truckers always loose to the inexperienced baby truck diesel people. the pyro belongs after the turbo so it can tell the temp of the turbo of course peterbilt, kenworth freihghtliner, cummins , cat , detroit mercedes etc dont know nuthin they only make engines that cost just about as much as your super duty and last a million miles. same with me,,32 years and 3 million miles and 4 big rigs under my belt never taught me a thing,,,,after the turbo.
Remember, our diesel engines in no way compare to the big rigs. Realize that first, and you'll understand that many people on this forum know exactly what they are talking about when it comes to pyro placement on a PSD. Post turbo pyro's have no use at all on these "baby trucks".
And yes it has been argued to death before. And the winner is the person who actually tested both pre and post turbo pyro temps. Want to know the result? Post turbo readings were completely unreliable. Most folks estimated that temp differences would be about 300 degrees cooler post turbo than pre turbo. In all reality, that temperature difference varied from 50 degrees all the way to 500 degrees. Engine load, RPM's, boost, air temps, altitude, etc all play a part in what the post turbo pyro readings will be. Imagine towing up a long steep mountain grade, and your post turbo pyro reads 900 degrees. You think you are safe because you believe that there is only a 300 degree difference between pre and post turbo readings. Now, if the actual difference at that time is 500 degrees between the two, you are actually at 1400 degrees pre turbo, and you are melting your pistons. Good bye engine.
So, for those who like to continue giving advice and recommending post turbo pyro placement, think twice. This is a $10K engine, and you are telling a likely rookie diesel owner to trust a gauge reading that could potentially destroy their motor. You won't see me recommending anything to a Mack/Freightliner/Detroit etc owner because I don't rely on my Powerstroke knowledge to apply accurately towards a big rig diesel.
Yeah I mounted it pre turbo in the pasanger side exhast manifold for that reason like I said at the beginning temperature is droped threw the turbo so I figured the temp behind the turbo would go up slower. pluss the main reason I wanted the pyro was so I could mess with the fule screw and pump timing safely.
Received 3,136 Likes
on
robinsonpowerstroke
12-30-2010 09:25 AM
73cntry
06-28-2010 07:21 PM
VX-23 Hokie
03-12-2006 01:32 PM
tdford
20
11-03-2005 10:47 PM
