General Diesel Discussion
zf trans swap??
Old Feb 20, 2008 | 10:27 PM
skoto1's Avatar
skoto1
zf trans swap??
anybody know what's involved in swapping a 85 f350 4 speed with pto for the zf 5speed. i already have the hydro clutch on mine and have swapped in a 7.3 from a 90 model the trans is coming from a 92 f350 7.3. will it bolt up to my 7.3 without any changes?
Old Feb 21, 2008 | 06:47 AM
mistakenID's Avatar
mistakenID
There should be no problem swapping in the ZF. Even the six speeds will work, with the exception of the speedometer. In newer trucks, the signal for speedometer is run off the rear axle.
Old Feb 21, 2008 | 09:22 AM
skoto1's Avatar
skoto1
great. thanks for the info.
Old Feb 21, 2008 | 04:52 PM
tjc transport's Avatar
tjc transport
i ain't rite
agreed. the only problem i can see is if the trans does not have a speedo cable port.
i don't remember if 92 was the first year for the vss tone ring in the rear diff or the last year for the cable drive in the tailshaft.
Old Feb 21, 2008 | 05:57 PM
skoto1's Avatar
skoto1
haven't seen the doner trans yet so ? i need the other gear i'll work around the speedo somehow.
Old Feb 22, 2008 | 12:07 PM
ubahd00d's Avatar
ubahd00d
isn't the speedo port on the transfer case though? Or is that only on the borg warner transfer cases? Would those bolt up to a zf6? If it does, wouldn't it not matter that there no speedo port on the zf6?
Old Feb 22, 2008 | 12:18 PM
skoto1's Avatar
skoto1
mines 2wd.
Old Feb 22, 2008 | 01:30 PM
tjc transport
i ain't rite
2 wheel speedo port is in the trans tail shaft, 4 wheel speedo port is in the transfer case tail shaft.
Old Feb 22, 2008 | 02:43 PM
ubahd00d's Avatar
ubahd00d
So could you put a ZF6 behind a 6.9 IDI 4x4 with the Borg Warner 1356 transfer case behind it?
Old Feb 22, 2008 | 03:47 PM
tjc transport
i ain't rite
sure, if the 1356 with speedo port will mount to the t-case flange on the trans.
Old Feb 23, 2008 | 08:56 AM
skoto1's Avatar
skoto1
this trans doesn't have the place for the speedo. and didn't come with a shifter any body got an extra laying around?
Old Feb 23, 2008 | 10:37 AM
Lead Head's Avatar
Lead Head
Not sure how much it would cost, but maybe you could find a 4x4, and take the transfer case and rear drive shaft, and hope it bolts upto the ZF?
Old Feb 23, 2008 | 01:29 PM
skoto1's Avatar
skoto1
correction. found a rubber plug and threaded hole under the grease on the tailshaft where you should be able to install the speedo gear . looks like i'm in business. i believe the clutch is going to be different because the input shaft looks bigger but i want know till i pull it. i still need the shifter but that's small stuff. thanks again.
