Sponsored by: Auxito
tailgate paint
Old Feb 2, 2008 | 06:08 PM
frdkid88's Avatar
frdkid88
tailgate paint
how much paint is needed to paint a f150 tailgate completly with 2 coats?
Old Feb 2, 2008 | 06:44 PM
tampa898's Avatar
tampa898
I would buy a quart if you can get it in that amount.
Old Feb 2, 2008 | 08:38 PM
frdkid88's Avatar
frdkid88
could i possibly buy cheap paint to paint the entire tailgate then spray the matched color on the outside to save money?
Old Feb 3, 2008 | 07:08 PM
sheetsd66's Avatar
sheetsd66
Not gonna save any money that way. I ain't never seen a paint store that'll sell you just enough paint to spray your project. If you buy a quart like tampa898 said you'll have lots left over.
Old Feb 3, 2008 | 07:11 PM
frdkid88's Avatar
frdkid88
i have a pint of matched paint and i was thinking of buying a quart of autozone red paint for the back side. I have a bedliner so i wont even see it
Old Feb 4, 2008 | 08:22 PM
sheetsd66's Avatar
sheetsd66
Are you trying to save the matched paint for something special? Why don't you just paint the whole thing with what you've got? By the time you mix it you'll have more than enough to cover the entire tailgate if you don't spray it all over the shop.
Old Feb 4, 2008 | 10:03 PM
frdkid88's Avatar
frdkid88
Will a pint cover the whole tailgate? I already have a pint of matched paint and i wasnt sure if that would cover the whole tailgate. So i figured i use cheap autozone paint to spray the back half and sides then spray the front with the matched paint. What im trying to avoid is ording more matched paint. The paint/clear coat has already cost me more then the tailgate itself i was just tring to do the job on the cheap a shop told me 300$$ for the whole job
Old Feb 7, 2008 | 05:29 PM
sheetsd66's Avatar
sheetsd66
I've painted an entire fill-size pickup, 3 coats inside and out- with just less than a gallon. I'm pretty sure you can put 2 coats on a tailgate with a pint. Is it metallic?
Old Feb 7, 2008 | 05:52 PM
frdkid88's Avatar
frdkid88
yes its metallic. what is the mix ratio? I've been practicing on my old junk bronco but other then that ive never painted.
Old Feb 7, 2008 | 06:33 PM
sheetsd66's Avatar
sheetsd66
Mix ratio depends on the kind of paint. I'd plan on 3 coats for metallic. Spray side-to-side first coat, let it tack up and spray top-to-bottom second coat, and even everything out with the final coat to get rid of any zebra stripes. If you're scared of running out cut it down to 2 coats on the inside that's gonna get covered with bedliner.
DieselCamper
Feb 6, 2017 08:02 AM
firstrider
Ford Truck Parts for Sale
Dec 5, 2016 12:45 AM
jcandela00
Sep 28, 2016 10:01 PM
Machman
May 1, 2016 06:04 PM
cweaver
Jul 16, 2015 09:01 PM
